2012-08-20, 10:13
OK so here goes.
I've been using XBMC for a while now and I love it , which makes my problem all the more frustrating now that it's not working like it's supposed to.
I had everything organized , and working perfectly .
Running out of storage space, I bought a couple of new hard disks (external) , to move all my tv/anime/movie content to.
Now here's where it all went wrong.
I uninstalled XBMC, cleaned all the files and folders for a fresh install and added the drives/folders again..however:
It just doesn't get correct info .
The shows all worked fine before I did not change the names of episodes or folders , they are just on a different drive now .
Examples :
I add the I drive to my videos (tv shows) .
It starts updating/scrapping , some shows are displayed correctly , others are not shown and all collected in a separate unnamed folder at the top.
All of the files in that folder are being named as being part of "How I Met Your Mother"..or "The Big Bang Theory"
I.e. Season 1 of Two and a Half Men , getting episode names belonging to HIMYM or TBT , I can see them gettting named wrong during updating.
Once updating is completed , I have this unnamed folder sitting at the top of my "TV Shows" dir..having 600+ episodes Originally belonging to various shows all wrongly named using episode names from HIMYM or TBT.
I.E. I'd have like 10 eps of "The Purple Giraffe" (Himym) , 10 of "Pilot" etc etc .
I can not remove the unnamed folder from the lybrary , and if I rename it the following happens :
I check the file path in the info of the unnamed folder , and it says it's supposed to be Alcatraz.
So I change the name of the unnamed folder to Alcatraz..
Now of those 600+ eps 44 of em are taken away and moved to a folder called Alcatraz, when I try to update the folder/tv show info...again it's wrong and giving episodes names from HIMYM or TBT..when updating is done The Alcatraz folder disappears and those 44 files merge with the unnamed folder again.
The same thing happens if I add each tv show folder separately .
Some of the tv shows do get correct info and episode names ,now here's the weirdest part :... it's not always the same shows !!
When I clear the library and database and start over ..sometimes shows that would end up in that huge unnamed folder with wrong episode names are added correctly , and others in turn, fail.
It's driving me nuts
Again : nothing has been altered when these files were moved , they have the same dir structure , same names ...just on a different drive (which I changed in XBMC ofc)
Any help would be greatly appreciated ..I really miss XBMC
Examples :
