2015-01-27, 19:21
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154
2015-01-27, 19:21
2015-01-27, 19:43
(2015-01-27, 16:01)Razze Wrote: [ -> ]@nonob
clean just deletes collected items you no longer have on your nas or wherever
It's what i want : when i delete a movie on my nas, i would like it will be removed also from my trakt collection, but actually it doesn't work..
I would like that my trakt collection be the mirror of my xbmc library so i could consult my movie collected list (on my nas) from an android app like seriesguide.
For now, my trakt collection display all movie i watched since the first time.
2015-01-27, 20:02
as some have noticed, a previous commit corrected the situation in which .strm files (virtual library items) were not being processed correctly, a quick fyi because it affects so many but i will try to avoid posting on the matter further because it often involves add-ons not supported here (forum rules)
2015-01-27, 20:23
How do I remove all traces of the script? Even when I uninstall it, it leaves some traces and when I re-install my credentials are still there. I would like to remove everything before I re-install to see if that will make a difference on my Windows 8.1 system.
Right now with the latest script from this morning, I still get frozen at 20% when sync'ing and it won't scrobble either. So I would like to start this from scratch.
2015-01-27, 20:55
I removed traces of the addon from my computer and reinstalled trakt addon. Now at least is seams to scrobble correctly. I see a progress bar. I'll post my findings when I rest further.
2015-01-27, 21:00
(2015-01-27, 20:23)RavRob Wrote: [ -> ]How do I remove all traces of the script? Even when I uninstall it, it leaves some traces and when I re-install my credentials are still there. I would like to remove everything before I re-install to see if that will make a difference on my Windows 8.1 system.
That's because the credentials and add-on settings are stored in the user data folder and need to be deleted. So for Windows:
Start > type:
%APPDATA%\kodi\userdata\addon_data\script.trakt
In addition to this, you'll need to delete the add-on itself. The add-on files can be found at:
kodi\addons\script.trakt\
Remove all the files. This should remove the add-on completely.
2015-01-27, 21:19
I just discovered Trakt.TV today. Pretty impressed with it so far, however when trying to get it to work with XBMC I had the obvious issues. I spent ages getting confused until I discovered this thread.
Using Razze's dev plugin, I get the scrobbling, but no syncing for my library (using the <strike>Genesis Plugin</strike> stream files).
It will be interesting to see how it goes. Good work so far!!
2015-01-27, 21:44
Is there anybody here who can help me with this problem?
https://github.com/Razzeee/script.trakt/...t-71703110
I dont know why the .six and .request directory are missing and i even dont know how to get them.
Any Ideas?
Any Ideas?
2015-01-27, 21:49
@Razze,
looks i got the right build now, but i still cannot sync my list of series.
Instead, it started marking all my episodes as watched.
2015-01-27, 21:56
(2015-01-27, 21:00)Hustler1337 Wrote: [ -> ](2015-01-27, 20:23)RavRob Wrote: [ -> ]How do I remove all traces of the script? Even when I uninstall it, it leaves some traces and when I re-install my credentials are still there. I would like to remove everything before I re-install to see if that will make a difference on my Windows 8.1 system.
Start > type:> press <Enter>Code:%APPDATA%\kodi\userdata\addon_data\script.trakt
Code:kodi\addons\script.trakt\
Tx Hustler
I did this and it now works. Scrobble, Sync movies and episodes all work as expected. Anyone else having problems, delete all traces of the Trakt addon and reinstall the latest build and it should work....did for me.
2015-01-27, 22:01
(2015-01-27, 21:44)jl88 Wrote: [ -> ]Is there anybody here who can help me with this problem?
Any Ideas?
so, i found these directories and installed it.
Now i have these Problems:
19:57:53 T:139897889355520 ERROR: Exception in thread trakt-sync:
File "/home/stephan/projects/openelec-4.2/build.OpenELEC-Generic.x86_64-4.2.1/Python-2.7.3/.install_pkg/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner
File "/storage/.xbmc/addons/script.trakt-dev/service.py", line 273, in run
sync.sync()
File "/storage/.xbmc/addons/script.trakt-dev/sync.py", line 643, in sync
self.__syncEpisodes()
File "/storage/.xbmc/addons/script.trakt-dev/sync.py", line 399, in __syncEpisodes
traktShowsUpdate = self.__compareShows(kodiShows, traktShows, watched=True)
File "/storage/.xbmc/addons/script.trakt-dev/sync.py", line 246, in __compareShows
if self.__countEpisodes([show_col1]) > 0:
File "/storage/.xbmc/addons/script.trakt-dev/sync.py", line 132, in __countEpisodes
for seasonKey in show[p]:
TypeError: 'NoneType' object is not iterable
Trakt freezed the system at this point, only reboot helps ...
2015-01-27, 22:16
Error while sync for me with new commit:
yesterday everything was ok ...
21:13:39 T:6012 ERROR: Exception in thread trakt-sync:
File "C:\Program Files (x86)\Kodi\system\python\Lib\threading.py", line 810, in __bootstrap_inner
self.run()
File "C:\Users\Marc\AppData\Roaming\Kodi\addons\script.trakt-dev\service.py", line 275, in run
File "C:\Users\Marc\AppData\Roaming\Kodi\addons\script.trakt-dev\sync.py", line 723, in sync
File "C:\Users\Marc\AppData\Roaming\Kodi\addons\script.trakt-dev\sync.py", line 689, in __syncMovies
File "C:\Users\Marc\AppData\Roaming\Kodi\addons\script.trakt-dev\sync.py", line 593, in __traktUpdateMovies
progress.close()
KeyError: 'imdb'
2015-01-27, 22:19
Any Ideas?
Get addons - Kodi addon repository - addon libraries
six and requests are in there
2015-01-27, 23:43
2015-01-28, 01:57
Just in case someone asks, I pushed code so that movies will show up in the collection with the actual date when it was collected (aka the file modified date) but there seems to be a bug in kodi. It's off by some hours.
http://trac.kodi.tv/ticket/15590
yeah, to add this correctly to shows I will need to refactor the compareShow method and thats the most complicated and most dangerous part of the whole thing.
You are sure you got it checked in the settings? Because it's working for me.
sorry, but it's in a dev branch for a reason.
(2015-01-27, 18:13)komplex Wrote: [ -> ]It now adds the date i watched a movie instead of just adding it the day it was synced, tv shows not so much it thinks i watched 80+ episodes last night lol
(2015-01-27, 19:43)nonob Wrote: [ -> ](2015-01-27, 16:01)Razze Wrote: [ -> ]@nonob
(2015-01-27, 22:16)locke45 Wrote: [ -> ]Error while sync for me with new commit:
Code:21:13:39 T:6012 ERROR: Exception in thread trakt-sync:
self.run()
progress.close()
KeyError: 'imdb'
