2015-02-25, 17:12
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154
2015-02-25, 22:06
which Transifex is used for this version of trakt ?
i found one but that's the old version
2015-02-25, 23:16
(2015-02-25, 22:06)TRaSH Wrote: [ -> ]which Transifex is used for this version of trakt ?
Sorry, forgot the link. https://www.transifex.com/projects/p/xbm...ipt-trakt/
As far as I know there wasn't a transiflex for the old one.
2015-02-26, 03:40
(2015-02-25, 15:13)darkmaffia Wrote: [ -> ](2015-02-25, 14:09)smakovits Wrote: [ -> ](2015-02-24, 23:21)smakovits Wrote: [ -> ]OK, got it, it's a per episode removal. Show is now gone, I'll see how it does next update.OK, with show removed, trakt updated thing last night and once again it is the wrong version of the show.
Inside kodi, thar site is correct.
remove any info files from this tv show folder.
Go to Kodi-tv shows and then refresh the information of your tv show. Let it skip the local files and get information from the internet.
I had almost the same problem once. It's not trakt related.
Now I want to go crazy. I removed the show from trakt, I removed it from kodi, I removed the nfo file I added. Refreshed library from tvdb and it once again brought the show in as the 1991 Prime Suspect as opposed to the 2011 one like it should be. I have no idea what and why at this point. If there are no good ideas and we cannot figure it out I might just delete it.
2015-02-26, 10:14
(2015-02-26, 03:40)smakovits Wrote: [ -> ](2015-02-25, 15:13)darkmaffia Wrote: [ -> ](2015-02-25, 14:09)smakovits Wrote: [ -> ]OK, with show removed, trakt updated thing last night and once again it is the wrong version of the show.
too bad.. Like I said I had ''almost'' the same problem. Maybe is yours different..
2015-02-26, 10:49
I just had to reinstall kodi on my machine, setup the library and then installed the trakt addon.
my expectation is that it now syncs the watched states from my trakt library to my kodi library, however this doesn't happen.
i have run the addon multiple times from programs, tried setting the option "sync after library update" however still it doesn't import my watched states.
scrobbling and adding new episodes to my trakt library works fine.
running the program i get to "retrieving episode collection from trakt" and then it just cuts out. (the progress bar isn't even halfway)
movies seem to be syncing the playstate however no TV shows :S
Am I doing something wrong?
2015-02-26, 11:00
(2015-02-25, 15:59)Razze Wrote: [ -> ]TLDR: Please everybody have a look at the translations again, they've reset to the point of the last sync so italian and danish updates were lost. (probably even more)
The danish should be fixed now.
2015-02-26, 11:01
(2015-02-26, 10:49)pseudoheld Wrote: [ -> ]I just had to reinstall kodi on my machine, setup the library and then installed the trakt addon.
I have the same problem. I started to use openElec on a raspberry PI 2.
My movie collection synced perfectly the watched states. The TV shows are missing completley.
Recently watched episodes were synced with trakt perfectly.
EDIT:
Okay, the log is clear. The server seems to be too busy:
10:08:26 T:6508 NOTICE: [trakt] [traktAPI] traktRequest(): Starting retry loop, maximum 5 retries.
10:08:26 T:6508 NOTICE: [trakt] [traktAPI] traktRequest(): (0) Request URL 'https://api.trakt.tv/user/library/shows/collection.json/b6135e0f7510a44021fac8c03c36c81a17be35d9/StrohhutMicha/min'
10:08:26 T:6508 NOTICE: [trakt] [traktAPI] __getData(): urllib2.Request(https://api.trakt.tv/user/library/shows/collection.json/b6135e0f7510a44021fac8c03c36c81a17be35d9/StrohhutMicha/min)
10:08:26 T:6508 NOTICE: [trakt] [traktAPI] __getData(): urllib2.urlopen()
10:08:26 T:6508 NOTICE: [trakt] [traktAPI] traktRequest(): (0) Server Busy ({"status":"failure","error":"server is over capacity"})
[/code]
2015-02-26, 11:25
There are some faults in the Dutch translation. I don't have permissions to the transiflex site (link) so how can I change them? Or who can I contact to make these changes?
2015-02-26, 12:27
Can you create an issue over at github and are you able to open files and replace or add some things I will send you?
You're both on the old version which is broken.
(2015-02-26, 11:25)Peekstra Wrote: [ -> ]There are some faults in the Dutch translation. I don't have permissions to the transiflex site (link) so how can I change them? Or who can I contact to make these changes?
If you got an transiflex account, you can apply for a place as dutch translator, check the wiki on that: http://kodi.wiki/view/Translation_System
2015-02-26, 12:52
(2015-02-26, 12:27)Razze Wrote: [ -> ]You're both on the old version which is broken.
kodi repo says im up to date...
do I have to grab a newer version somewhere else??
2015-02-26, 12:57
(2015-02-26, 12:52)pseudoheld Wrote: [ -> ](2015-02-26, 12:27)Razze Wrote: [ -> ]You're both on the old version which is broken.
I'm still finalizing the new version, so it's not yet in the kodi repo. If you really want it check https://github.com/Razzeee/script.trakt and read the installation instructions
2015-02-26, 13:10
(2015-02-26, 12:57)Razze Wrote: [ -> ](2015-02-26, 12:52)pseudoheld Wrote: [ -> ](2015-02-26, 12:27)Razze Wrote: [ -> ]You're both on the old version which is broken.
followed the steps on github but it still grabs the 2.3.2 version not the 3.0.0
https://github.com/rectifyer/script.trak...all/master
Following that link gives me 2.3.2
where/how can i get the 3.0.0?
2015-02-26, 13:11
(2015-02-26, 13:10)pseudoheld Wrote: [ -> ](2015-02-26, 12:57)Razze Wrote: [ -> ](2015-02-26, 12:52)pseudoheld Wrote: [ -> ]kodi repo says im up to date...
Click on the "Download ZIP" on the right side of the page.
You should delete the old version first btw.
2015-02-26, 13:28
(2015-02-26, 13:11)Razze Wrote: [ -> ]Click on the "Download ZIP" on the right side of the page.
ok great installed that. now its up to date (3.0.0) however trakt sync wont start once i launch it manually.
settings work fine but when i try to access trakt from programs it just doesn't launch anything.
does the 3.0.0 plugin have any new dependancies? (the old once needed six and requests both of which i have installed)
