(2015-03-02, 23:49)Razze Wrote: [ -> ] (2015-03-02, 23:47)Warner306 Wrote: [ -> ]Is there a repo version of this add-on available? I am looking for an auto-update as it seems this add-on is constantly changing.
There's only a beta repo for now, but it will be pushed to the official after the next transiflex translation update.
The last one was six days ago, so there should be a new one soon.
Thanks, I appreciate your work in restoring this add-on.
(2015-03-01, 19:36)TRaSH Wrote: [ -> ]Took a look it tells me I don't have access,
I got a transiflex account,
Not sure if you need help for the Dutch transnational.
Noticed a part in the dev release what wasn't translated.
Last week I made a big update to the Dutch translation in Transiflex. I'm not entirely sure how it works but I guess it's up to Razzee to commit them to the Github repository at some time.
(2015-03-03, 11:30)Peekstra Wrote: [ -> ] (2015-03-01, 19:36)TRaSH Wrote: [ -> ]Took a look it tells me I don't have access,
Yep, I have to commit them, but first I have to get tem exported. That what the kodi team does periodically.
So I'm also just waiting.
Just got new translations can someone fix this portuguese translation?
https://www.transifex.com/projects/p/xbm...ipt-trakt/
Quote:Addon: script.trakt, Lang: pt, Warning: count missmatch of char "%"
msgctxt "#32109"
msgid "Playcounts updated for %i show(s) in Kodi"
msgstr "Atualizado o número de vizualizações para %i de %i episódio(s) no Kodi"
There should only be one %i
(2015-03-03, 13:10)fightnight Wrote: [ -> ]Code:
Número de visualizações actualizado em %i série(s) no Kodi
Is that a language string? I see that causing an issue.
I've updated the French translation up to 100% and revised few things.
(2015-03-03, 16:19)Piers Wrote: [ -> ] (2015-03-03, 13:10)fightnight Wrote: [ -> ]Code:
That is the correct translation for the string.
My Kodi on Windows 7 PC (let's call it PC1) syncs movies and TV Shows to Trakt.tv website but when I change computers, the watched TV Shows and movies do not sync with my Kodi on Windows 8 PC (let's call it PC2). Is this an expected behaviour?
Thanks in advance.
(2015-03-03, 18:05)bullittbirant Wrote: [ -> ]Hi,
Thanks in advance.
Veryfy that your on version 3.0.0 on both of them. Also check if you have activated both
"Mark XXX from trakt history as watched in Kodi"-Settings
Hi Razze,
I forgot to tell that I am at the latest stable version 2.3.1 (if I'm not mistaken). When you say version 3.0.0 isn't it the beta version?
Thanks in advance.
(2015-03-03, 18:18)bullittbirant Wrote: [ -> ]Hi Razze,
Thanks in advance.
Your correct.
That feature is broken in 2.3.2 and prior. Due to website changes.
Where can I download the v3.x.x? Could not find the link in github.
Thanks in advance.
(2015-03-03, 20:20)bullittbirant Wrote: [ -> ]Where can I download the v3.x.x? Could not find the link in github.
Thanks in advance.
you can download from github:
https://github.com/Razzeee/script.trakt/tree/dev (use download zip button on right)
as i understand things it pretty close to being submitted to the kodi repository so if not familiar with github or manual install/uninstall of add-ons you might want to wait for distribution via official kodi repository, this is still a beta so problems may yet be encountered
p.s. - i only had a moment to reply, i will try to provide a more complete answer shortly
