2012-08-21, 10:44
2012-08-21, 11:11
Take a look here:
http://wiki.xbmc.org/index.php?title=Use...3Cvideo.3E
Quote:<playcountminimumpercent>90</playcountminimumpercent> <!--Minimum percentage that has to be played before it is marked as watched. Set to 101 to never auto-mark items as watched -->
2012-08-21, 11:19
Create a text file and save it as "advancedsettings.xml (wiki)" inside of your userdata (wiki) folder with the following content:
EDIT: Ah, Fry7 beat me to it :D
<advancedsettings>
<video>
<playcountminimumpercent>101</playcountminimumpercent> <!--Minimum percentage that has to be played before it is marked as watched. Set to 101 to never auto-mark items as watched -->
</video>
</advancedsettings>
2012-08-21, 17:15
Thanks guys.
You are amazing!!
A quick question about playback position.
When I have an unexpected system shutdown or power failure , my xbmc does not remember playback position.
Can you guide me what's wrong ?
You are amazing!!
2012-08-21, 18:05
I'd guess that in case of a power or system failure XBMC simply does not get the time to write the last playback position into its database, so I don't believe that's something that XBMC should take care for.
If that should happen to you often, maybe there is a hardware or OS issue on your htpc which should be taken care of...
2012-08-21, 18:22
Doesn't XBMC keeps track of playback position and writes back to file all the time. i mean even if it doesn't get time for the most recent playback position, I'll still be able to recall last saved position.
Before using XBMC i had a WDTV live, it never missed playback positions. Even power failures didnt caused lost positions.
2012-08-25, 04:28
XBMC avoids writing to a disk all the time (often called disk thrashing). While it can be seen as good in this case, often it's not and just causes unneeded wear on the drive. This is especially true for SSDs and boot USB drives.
