Full Version: XBMC “APPCRASH“ issue
Hi everybody, I have a huge problem with my XBMC. The program crashes randomly after 20-30 minutes.
Here you can see the Windows error message:
And the XBMC.log file:
http://pastebin.com/FcrgXsmC
My system:
XBMC 11.0 Final from Download section at www.xbmc.org
Skin Aeon MQ3 2.0.1 (latest version I think)
Windows 8 64bit (RTM V: 9200, without any Patches)
CPU: AMD A6-3500
RAM: 4GB Kingston 1866
Video Card: IGP – Radeon HD 6530D – Driver Version: 8.982 with Catalyst Suite 12.8, newest for Win8
Sound Card (onboard on Asrock A75M-ITX) Driver Version: R2.62
If necessary:
My TV: LG 47lm 660 (yes European Version, because I’m from Germany. It should be the same as lm6600/lm6700)
AV-Receiver: Yamaha RX-A2010
For all the people thinking of Windows 8 could be the Problem, I have to deny. I had the same issue with Windows 7 64bit.
Hopefully someone has an idea ….
Debugging needs to be turned on for the debug log. Go to Settings/System/Debugging (wiki) and enable debug logging.
ahhh...shit my fault
I will turn it on when I come home after Work and post the right log here.
here you go my Log file with Debug mode ON:
http://pastebin.ubuntu.com/1159523/
Thx for helping me
No idea ?
no one ?
I think I found the problem by myself...
It seems the upnp option was my problem, after I turned it off (cause I don't need, have no idea why it was ON)
everything went well.
In my debug log there's a very long upnp query at the end and I have no idea why but then it crashs.
Very odd. Possibly some rare (?) UPnP issue.
yeah maybe, but for me it doesn't matter cause I, as mentioned, don't use it and will not use it in near future. So I'm just happy it works properly again.
But feel free to use my log-file for research on this Problem.
