Full Version: New HTPC for grad student.
Hey guys:
I am interested in building an HTPC for some gaming. Not necessarily the highest settings but enough to be comparable to my XBOX 360. I want to get rid of the XBOX 360 for some spare cash. I am currently a grad student so money is a little low, but I desperately need a server and an HTPC to keep me mildly entertained. I wanted to go for an A8 build that was Mini-ITX, but am afraid of heat and power issues. Here is what I have got so far.
AMD A8-3870K Unlocked Llano 3.0GHz Socket FM1 100W Quad-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD
LITE-ON Black Internal 12X Blu-ray Combo SATA Model ihes112-04 - OEM
Western Digital 2 TB WD Green SATA III Intellipower 64 MB Cache Bulk/OEM Desktop Hard Drive
MI-008 Tower Black P4 Chassis with 250W Itx Psu+sata Power Supply
Corsair XMS3 4 GB 1333MHz PC3-10666 240-pin DDR3 Memory Kit for Intel Core i3 i5 i7 and AMD CMX4GX3M1A1333C9
If anyone could help get a cheaper or similar price build, I would greatly appreciate it.
I would say my budget is roughly 400-450. I am less interested in gaming really, but I do play occasionally. I would say that an XBOX 360 on Ebay would get me maybe 100-150 dollars. If it is cheaper to simply build a media machine for 100-150 cheaper and keep the XBOX 360 for gaming that would be acceptable also, but I am leaning towards the one machine style.
Any particular reason for A8-3870K?
A6's will do the job if you're on a tight budget.
New egg is offering a deal for 183 for the motherboard and A8 together.
(2012-08-21, 22:24)CrazyDesi Wrote: [ -> ]New egg is offering a deal for 183 for the motherboard and A8 together.
What Motherboard is it offering? or do you have a link to the deal?
You'll have heat issue with an A8-3870K in MI-008 case. You can opt for lower power Intel G640+AMD HD6450+ASRock B75M-ITX instead......it'll run cooler and use less power......
(2012-08-21, 21:46)CrazyDesi Wrote: [ -> ]If anyone could help get a cheaper or similar price build, I would greatly appreciate it.
That CPU is going to be a problem in that case.
Take a look at my hardware guide. I have some better and cheaper options.
