I followed this (
http://wiki.xbmc.org/index.php?title=HOW..._libraries) guide to try and set up multiple libraries.
However I seem to be having problems.
When I add the media to my xbmcbuntu the database in mysql isn't created.
Also if I try to boot xbmc in my windows machine it just hangs on the splash screen
This is from the windows machine
00:45:34 T:3480 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
00:45:34 T:3480 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.198.0.9</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</musicdatabase>
<loglevel hide="false">2</loglevel>
</advancedsettings>
00:45:34 T:3480 NOTICE: Log level changed to 2
00:45:34 T:3480 WARNING: VIDEO database configuration is experimental.
00:45:34 T:3480 NOTICE: Getting hardware information now...
00:45:34 T:3480 INFO: Using analog output
00:45:34 T:3480 INFO: AC3 pass through is enabled
00:45:34 T:3480 INFO: DTS pass through is enabled
00:45:34 T:3480 INFO: AAC pass through is disabled
00:45:34 T:3480 INFO: MP1 pass through is disabled
00:45:34 T:3480 INFO: MP2 pass through is disabled
00:45:34 T:3480 INFO: MP3 pass through is disabled
00:45:34 T:3480 NOTICE: Checking resolution 12
00:45:34 T:3480 NOTICE: Default DVD Player: dvdplayer
00:45:34 T:3480 NOTICE: Default Video Player: dvdplayer
00:45:34 T:3480 NOTICE: Default Audio Player: paplayer
00:45:34 T:3480 NOTICE: Disabled debug logging due to GUI setting. Level 1.
00:45:34 T:3480 NOTICE: Log level changed to 1
00:45:34 T:3480 NOTICE: Loading media sources from special://masterprofile/sources.xml
00:45:34 T:3480 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
00:45:34 T:3480 DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "Motorola Nyxboard Hybrid"
00:45:34 T:3480 DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "Pulse-Eight CEC Adaptor"
00:45:34 T:3688 DEBUG: Thread XBMC Peripherals start, auto delete: 0
00:45:34 T:5024 DEBUG: Thread CRemoteControl start, auto delete: 0
00:45:34 T:3480 DEBUG: CWinEventsWin32::WndProc: window resize event
00:45:34 T:3480 DEBUG: CWinEventsWin32::WndProc: window move event
00:45:34 T:3480 DEBUG: CWinSystemWin32::ResizeInternal - resizing due to size change (0,0,1366,768 fullscreen)->(0,0,1366,768 fullscreen)
00:45:34 T:3480 DEBUG: CWinEventsWin32::WndProcWindow is active
00:45:34 T:5024 DEBUG: CRemoteControl::Connect - connecting to: ::1:24000 ...
00:45:35 T:3480 DEBUG: CRenderSystemDX::InitRenderSystem - trying D3D9Ex...
00:45:35 T:3480 DEBUG: CRenderSystemDX::InitRenderSystem - using D3D9Ex
00:45:35 T:3480 DEBUG: CRenderSystemDX::CreateDevice on adapter 0
00:45:35 T:3480 DEBUG: CRenderSystemDX::CreateDevice - using hardware vertex processing
00:45:35 T:3480 DEBUG: CRenderSystemDX::CreateDevice - adapter 0: igdumdx32.dll, Intel(R) HD Graphics, VendorId 32902, DeviceId 70
00:45:35 T:3480 DEBUG: CRenderSystemDX::CreateDevice - using D3DCAPS2_DYNAMICTEXTURES
00:45:35 T:3480 DEBUG: CRenderSystemDX::CreateDevice - texture caps: 0x0021EC45
00:45:35 T:3480 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_DXT
00:45:35 T:3480 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_NPOT
00:45:35 T:3480 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_DXT_NPOT
00:45:35 T:3480 DEBUG: CRenderSystemDX::CreateDevice - Intel workaround - specifying minimum pitch for compressed textures.
00:45:35 T:3480 DEBUG: CWinSystemWin32::SetFullScreen (windowed fullscreen) on screen 0 with size 1366x768, refresh 60.000000
00:45:35 T:3480 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
00:45:35 T:3480 INFO: load default splash image: C:\Program Files (x86)\XBMC\media\Splash.png
00:45:35 T:3480 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib.dll)
00:45:35 T:3480 INFO: Loading special://xbmc/system/IRSSmap.xml
00:45:35 T:3480 INFO: * Adding remote mapping for device 'Microsoft MCE'
00:45:35 T:3480 INFO: * Adding remote mapping for device 'Abstract'
00:45:35 T:3480 DEBUG: CButtonTranslator::Load - no userdata IRSSmap.xml found, skipping
00:45:35 T:3480 INFO: GUI format 1366x768 1366x768 @ 60.00 - Full Screen
00:45:35 T:3480 DEBUG: guilib: Fill viewport always for solving rendering passes
00:45:35 T:3480 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcurl.dll)
00:45:35 T:3480 NOTICE: initializing playlistplayer
00:45:35 T:3480 NOTICE: DONE initializing playlistplayer
00:45:35 T:3480 DEBUG: DPMS: supported power-saving modes: OFF STANDBY
00:45:35 T:5024 DEBUG: CRemoteControl::Connect - connecting to: 127.0.0.1:24000 ...
00:45:35 T:3480 INFO: Unloading old skin ...
00:45:35 T:3480 INFO: load skin from:C:\Program Files (x86)\XBMC\addons\skin.confluence
00:45:35 T:3480 INFO: load fonts for skin...
00:45:35 T:3480 INFO: Loading fonts from C:\Program Files (x86)\XBMC\addons\skin.confluence\720p\Font.xml
00:45:36 T:3480 INFO: Loading skin includes from C:\Program Files (x86)\XBMC\addons\skin.confluence\720p\includes.xml
00:45:36 T:3480 INFO: load new skin...
00:45:36 T:3480 INFO: Loading skin file: Home.xml
00:45:36 T:5024 ERROR: CRemoteControl::Connect - failed to connect
00:45:36 T:5024 INFO: CRemoteControl::Process - failed to connect to irss, will keep retrying every 5 seconds
(I removed some things to stay in the character limit)
XBMC will load up if the mysql lines are removed from the advancedsettings.xml
And on the XBMCbuntu I have been getting lots of these:
00:24:07 T:3014654832 ERROR: Unable to open database: MyVideos60 [2003](Can't connect to MySQL server on '192.168.0.9' (111))
I have tried fiddling with the mysql settings with no luck
Last library update left none of those errors at all. Still no mysql database made though
Use pastebin.com or xbmclogs.com to post the whole logs. It sounds like XBMC might not have the right access on the MySQL server, but I'm not sure.
Windows:
http://pastebin.com/Jcd98zjt
I can't paste the ubuntu log at the moment. It is too big.
I'll boot it up tomorrow and post the log then
