Full Version: Xbmc on 1680*1050 Monitor
Hey,
I just got an old monitor and i´m wondering if i could use it for my bedroom htpc.
Unfortunately it´s only capable of a resolution of 1680*1050.
Is it possible to force it to display Full HD (and let it downscale).
I´m asking because i don´t think Xbmc skins are very compatible with 16:10, right?
Downscaling is easy, no issue there. As for 16:10, they'll stretch a little bit, but it won't be very noticeable. Jezz_X made a 16:10 version of Confluence once that works pretty nice, if you do notice the stretching and it bothers you. I'll see if I can hunt up a link for it.
You can also calibrate the XBMC GUI to use a 16:9 space, so that there are black bars at the top and bottom.
Thanks for the reply!
I tried to force 1080p on it and it works reasonably well.
Of course it´s very visible that it´s not native when i´m webbrowsing but it´s barely noticeable in xbmc.
