I am running XBMC on ATV2.
In my video folder I have a lot of subfolders for TV shows. Many are empty a lot of the time except for a folder.jpg.
I also have a WDTV and it ignores all the folders that do not contain a video file type. Is there a way to make XBMC ignore the folders that don't contain a video file?
Thanks for any help.
You can drop them from the library. Check the advanced settings page in the wiki.
You can't drop them from the files listing, however.
I guess I should propose that as a suggested feature then.
Then how do most people do this? Clearly I've got my folder structure different than most. Everyone can't be weeding through empty folders on a daily basis.
they don't have empty folders...
(2012-08-26, 06:57)jmarshall Wrote: [ -> ]They use the library.
I'm using the library, if I read between the lines am I to believe the library will not hide empty folders either? There is currently no way to only see folders with video content within?
(2012-08-26, 11:31)Memphiz Wrote: [ -> ]they don't have empty folders...
Sickbeard will not function properly or handle post processing if the destination folder is not present.
Make a text file called advancedsettings.xml and place it in the
userdata folder (wiki) with the following content:
<advancedsettings>
<videolibrary>
<hideemptyseries>true</hideemptyseries> <!-- hide empty series in the video library -->
</videolibrary>
</advancedsettings>
(2012-08-28, 03:02)Ned Scott Wrote: [ -> ]Make a text file called advancedsettings.xml and place it in the userdata folder (wiki) with the following content:
<advancedsettings>
<videolibrary>
</videolibrary>
</advancedsettings>
AWESOME!! Worked like a charm.
Thanks very much for taking the time to post. Makes XBMC soooooo much more useable for us.
