Full Version: remote.xml needs correction to work
I had a remote.xml working perfectly just a week ago, then my install broke (openElec beta, something just fucked up) and I needed to reinstall (couldn't access the files).
I have fixed everything now with the new installation (thx openELEC for quick install) except the remote.xml.
Here is what I have atm:
<keymap>
    <FullscreenVideo>
        <remote>
            <CHANNELUP>SubtitleDelayPlus</CHANNELUP>
            <CHANNELDOWN>SubtitleDelayMinus</CHANNELDOWN>
        </remote>
    </FullscreenVideo>
</keymap>
But it doesn't work, probably just a little error somewhere.
I checked in irw what the name of the buttons were, and put them in the tags (as you can see).
What is wrong? Smile
Enable debug log (wiki)ging in XBMC and then press those buttons on the remote. Exit XBMC and examine your debug log (wiki) to see how XBMC identifies those keypresses.
Here:
20:46:01 T:140434741327680 DEBUG: LIRC: Update - NEW at 22025841:192 0 KEY_CHANNELUP devinput (KEY_CHANNELUP)
20:46:01 T:140434741327680 DEBUG: OnKey: leftshift (d2) pressed, action is PageUp
20:46:01 T:140434419468032 DEBUG: DoWork - took 113 ms to load special://skin/backgrounds/music/music.jpg
20:46:01 T:140434741327680 DEBUG: LIRC: Update - NEW at 22026179:192 0 KEY_CHANNELUP_UP devinput (KEY_CHANNELUP_UP)
20:46:02 T:140434741327680 DEBUG: LIRC: Update - NEW at 22027225:193 0 KEY_CHANNELDOWN devinput (KEY_CHANNELDOWN)
20:46:02 T:140434741327680 DEBUG: OnKey: rightshift (d3) pressed, action is PageDown
20:46:02 T:140434741327680 DEBUG: LIRC: Update - NEW at 22027745:193 0 KEY_CHANNELDOWN_UP devinput (KEY_CHANNELDOWN_UP)
Oh fuck. I think I know the solution. Of course it is PageUp and PageDown. Thx for the tip!
