Just wondering if anyone here had a full systemd setup and XBMC running on it. So far, I have gotten XBMC autologin to work on systemd, but it fails to connect to D-Bus, so I cannot suspend/shutdown/reboot/hibernate.
Arch Linux will somewhere in the future be switching to systemd, so I am migrating my systems, but the D-Bus thing is proving a particular PITA.
So, any takers?
I've got two boxes running Arch 32-bit that switched over to systemd a couple weeks ago and I have suspend, resume, reboot and shutdown working (haven't tried Hibernate but it appears on the XBMC shutdown menu). I don't have XBMC running as a systemd service. I set up a service that launches mingetty to autologin (as user xbmc). Based on similar instructions I found somewhere to autolaunch agetty, I created a file called /etc/systemd/system/
[email protected]:
# This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2.1 of the License, or
# (at your option) any later version.
[Unit]
Description=Getty on %I
Documentation=man:mingetty(8)
After=systemd-user-sessions.service plymouth-quit-wait.service
After=rc-local.service
# If additional gettys are spawned during boot then we should make
# sure that this is synchronized before getty.target, even though
# getty.target didn't actually pull it in.
Before=getty.target
IgnoreOnIsolate=yes
# On systems without virtual consoles, don't start any getty. (Note
# that serial gettys are covered by [email protected], not this
# unit
ConditionPathExists=/dev/tty0
[Service]
Environment=TERM=linux
# the VT is cleared by TTYVTDisallocate
ExecStart=-/sbin/mingetty --autologin xbmc tty1 linux
Type=simple
Restart=always
RestartSec=0
UtmpIdentifier=%I
TTYPath=/dev/%I
TTYReset=yes
TTYVHangup=yes
TTYVTDisallocate=yes
KillMode=process
IgnoreSIGPIPE=no
# Unset locale for the console getty since the console has problems
# displaying some internationalized messages.
Environment=LANG= LANGUAGE= LC_CTYPE= LC_NUMERIC= LC_TIME= LC_COLLATE= LC_MONETARY= LC_MESSAGES= LC_PAPER= LC_NAME= LC_ADDRESS= LC_TELEPHONE= LC_MEASUREMENT= LC_IDENTIFICATION=
# Some login implementations ignore SIGTERM, so we send SIGHUP
# instead, to ensure that login terminates cleanly.
KillSignal=SIGHUP
[Install]
Alias=getty.target.wants/[email protected]
WantedBy=graphical.target
Created the following symlink:
Then I enabled the service with:
I start X from ~/.bashrc:
if [ -z "$DISPLAY" ] && [ $(tty) == /dev/tty1 ]; then
startx
logout
fi
and XBMC launches from ~/.xinitrc with:
exec ck-launch-session /usr/bin/xbmc --standalone &> /dev/null
I tried a few other variations before this worked so hopefully I haven't omitted something.
Wow, thanks. That is one hefty systemd file. I use autologin as well now on the traditional init system, I'll give your stuff a shot.
Just wanna thank you guys.
Now systemd is fun again
If you use lightdm or other DE, you can setup auto-login through it and it will register you with consolekit/policykit/dbus
You can possibly setup xrandr and keyboard layouts with scripts.
(2012-09-01, 04:17)mrchris Wrote: [ -> ]Code:
startx
logout
fi
What does the "logout part" do?
ConsoleKit will interefere with systemd-login so it should be:
exec /usr/bin/xbmc-standalone
That's why I leave it to lightdm to autologin to the XBMC session. Lightdm will take care of whatever ck, polkit, d-bus requirements there are and additionally you can setup displays, touchpad, etc with lightdm scripts because it would be harder to do in console before XBMC is started.
