I remember awhile back there was something to include in the advancedsettings file which would display a notification if there was more than one audio track in a video file. Can anyone tell me if this is possible? I have a lot of vid files which have 2 audio tracks. Thanks.
<tuxbox>
<!-- "audiochannelselection"; default is 'false', 'true' will popup the audio channel selection if
there is more then one audio stream !-->
<audiochannelselection>false</audiochannelselection>
<!-- "submenuselection"; default is 'false', 'true' will popup the Submenu selection !-->
<submenuselection>false</submenuselection>
<!-- "defaultrootmenu"; MODE: 0 = TV (Default), 1 = Radio, 2 = Data, 3 = Movies, 4 = Root !-->
<defaultrootmenu>0</defaultrootmenu>
<!-- "defaultsubmenu"; 1=Services 2=Satellites 3=Providers 4=Bouquets (default) !-->
<defaultsubmenu>4</defaultsubmenu>
<!-- "pictureicon"; default is 'true', will use the Picture Icons from folder /UserData/PictureIcon/ !-->
<pictureicon>true</pictureicon>
<!-- "epgrequesttime"; default is '10', 0-3600, defines the time in seconds between epg queries, some tuxbox
devices need longer to response (Minimum: 1, Maximum: 3600) !-->
<epgrequesttime>10</epgrequesttime>
<!-- "zapwaittime"; default is '0' (0 = OFF), defines the time in seconds to wait for a valid PMT after the
zaping was send (Minimum: 0, Maximum: 120) !-->
<zapwaittime>0</zapwaittime>
</tuxbox>
Thanks. Like this?
<tuxbox>
<audiochannelselection>true</audiochannelselection>
</tuxbox>
looks about right to me...
I just found that in the wiki.. I don't use it myself.
(2012-08-30, 04:02)Ardalista Wrote: [ -> ]looks about right to me...
Tried it. Don't work.
did you remember to enclose it between <advancedsettings> and </advancedsettings>
(2012-08-30, 04:31)Ardalista Wrote: [ -> ]did you remember to enclose it between <advancedsettings> and </advancedsettings>
Yup. I think it might not work with the new audio engine
