Full Version: Microserver N40L questions
Hi All,
Ive just recently purchased an N40L Microserver and upgraded to 8gb RAM, a HD5450 graphics card and added a 2TB HD alonside the stock 250gb.
I'll explain what im trying to achieve and maybe someone can help and suggest if a) its possible b) it will work c) any advice / guidance to help me on my quest Smile
I want to setup the Microserver as a VM server (ESXI?) so that i can have the following:
VM for Windows 7 (XBMC, Couchpotato, sickbeard, SABNZBD etc or should i put couchpotato / sickbeard sab on another VM?) I want to use the server also as a media centre connected to my tv.
VM for MYSQL for XBMC server.
VM for a file server (Samba? Grayhole? or something else?)
I want to be able to access the content on the microserver from any other XBMC install around the house or remotely on an iOS, Raspberry Pi or A.N.Other device etc.
I will use the stock 250gb for the VMs and the 2tb for the data/media. Should i also use a USB flash drive for the ESXI install or can i just do this on the 250gb?
Ideally i want to be able to add additional hard drives in the future and pool them (seen something called greyhole that might do this?)
Any help would be great as there are so many tutorials but pinning them all together to achieve what im trying to achieve (and if its at all possible) is becoming a nightmare!
Regards
Superblades
Welcome to the forum
Looks like you want to jump in with both feet, but are using your big toe thermometer Smile I don't have many of the answers you seek and I doubt there are too many that could, so I suggest you will get better attention in the hardware forum http://forum.xbmc.org/forumdisplay.php?fid=112 ;you'll also find the information in that area which will point you in the correct direction. It all may look daunting at first, but taking it one step at a time will allow you to see the big picture clearly, my fav link is the last one...
Here's a few outside links which may cast a different perspective.
http://lifehacker.com/5771670/how-to-tur...o-recorder
http://forum.xbmc.org/showthread.php?t=120406
http://lifehacker.com/5536963/the-ultima...dia-center
http://lifehacker.com/5900626/create-a-k...lete-guide
