Full Version: How to tag Videos as Concerts?
i am sorry to put that question here, but i swear that i have taken use of the search function.
I have also tried to use any menu item which i was able to find to tag a directory or a file to reflect the state of being a concert.
All my Concert-Videos reside in one directory
The Directory has been added as source, the content-type is set to musicvideo.
What else do i have to do to let them appear under the concerts menu item in aeon mq3?
Any help, hint or external link is very appreciated,
thanks in advance,
nailz
P.S.: i am running Eden on Ubuntu, self compiled.
I've found a solution:
1. create a folder named concerts
2. move all concerts in that folder
3. videos -> files -> add videos
4. enter path to your concerts folder, give it a meaningful name
5. set content as "music videos", check automatic scan, select "music videos tmdb mq" as scraper (i've had to do this multiple times until it worked!)
6. if your're asked if scanning should occur, say yes
If you already have a folder containing concerts:
1. videos -> files -> highlight your concertsource
2. hit "c" on your keyboard and select "set content". then continue with step 5 from above.
^thanks for this. i am still setting up mq3 but this is definitely a question i was eventually going to ask. lol
Or you can...
- add the concertdb
-go to movies, files, add videos..
- give you concert folder
-set content as music videos, set concertdb as scraper
Go to main menu and they will be under concerts..
