Full Version: How to use Confluence again.
Hi
I used Confluence (the default skin), then i instaled a new one just to try (Aeon nox).
Now i want to go back to default Confluence skin, but i'm unable to delete addon Aeon nox, or switch to default Confluence skin..
Am i missing something? how can i revert to default skin?
Best regards
Ricardo
Welcome to the XBMC forums.
System > Settings > Appearance > Skin > Skin: Confluence
No artrafael, that did not work as i only had Aeon NOX as active to select!
there was no Confluence there. and there was no option to delete aeon nox either.
however i found the path to aeon nox folder and deleted it. This way, Confluence became the skin again.
