I have XBMC on OSX.
I installed SuperTV sometime ago but uninstalled it because of the memory issues. I was checking my system log the other day and to my surprse I saw the following errors: (every 10 seconds)
May 18 00:52:18 com.xbmc.SuperTV[3047]: /bin/bash: line 0: cd: /Users/JWBdata/Library/Application*Support/XBMC/addons/SuperTV: No such file or directory
May 18 00:52:18 com.xbmc.SuperTV[3047]: python: can't open file 'update.py': [Errno 2] No such file or directory
May 18 00:52:18 com.apple.launchd.peruser.501[121] (com.xbmc.SuperTV[3047]): Exited with code: 2
May 18 00:52:18 com.apple.launchd.peruser.501[121] (com.xbmc.SuperTV): Throttling respawn: Will start in 10 seconds
How can I remove all refernce to SuperTV on my system? So I don;t get these messages?
Thanks,
JW
No more Penthouse HD?. I miss that channels. Anyone know where i can get some XXX Channels in Navi-X?...Thanks
Can anyone help I love this plugin and especially the uk filmon channels but as the other channels in this list aren't working is their anyway I can add my own list have tried doing this by adding a link to my weblist in the default.py but always get script error when I try to run it. Has anyone been able to do this? Thanks
umonkey, it is supposed to work fine.
Give us an example of what your default.py looks like. You can also check hte xbmc.log file after you get the script failed error.
Thanks maniac for the reply, will post my default.py when i get home and if you see no error will then look at the log and if i need help with this will post it also.
Thanks again.
Hey Maniac, here's what my default.py looks like
#!/usr/bin/env python
# -*- coding: utf-8 -*-
if __name__ == "__main__": from resources.lib.main import main
BASE=[
('https://raw.github.com/HansMayerXBMC/SuperTV/master/resources/xml/United%20Kingdom.xml', 'United Kingdom'),
('http://home.no/chj191/LiveTV.xml',"blackoutworm's list"),('http://home.no/chj191/xxx.xml',"blackoutworm's XXX list"),('http://www.home.no/thatguy7669/sports.xml',"thatguy"),
if __name__ == "__main__": main(BASE).
This was just a test to see if i can get it to work just used someone else's list so that i can then make my own xml list later when i have got it working
After trying it with superTV (as i use rtmpgui+ Should i be able to do this with rmtpgui+
) i don't get script error it just doesn't load the channel list ? but get script error with rtmpgui+
thanks again for you help.
Getting the following error .. Does anyone know what the issue is ?
Using SuperTV 1.105.5 with latest libRTMP. Tried to update to latest SuperTV 1.105.7 but add-on is enabled but still show 1.105.5 so I am assume still on old version.
any help appreciated.
06:34:52 T:140251136 NOTICE: ['rtmp://tv.futubox.com/live playpath=z010601.stream swfurl=http://www.tvsector.com/wp-content/uploads/jw-player-plugin-for-wordpress/player/player.swf pageurl=http://www.futubox.com/', <resources.lib.epg.SkyUKEPG instance at 0x8e0046c>, ['http://tv.futubox.com:1935/live/z010601.stream/playlist.m3u8'], 'skyuk', 'http://upload.wikimedia.org/wikipedia/de/thumb/e/ec/Eurosport_HD_2011.svg/1000px-Eurosport_HD_2011.svg.png']
06:34:52 T:99766272 NOTICE: DVDPlayer: Opening: rtmp://tv.futubox.com/live playpath=z010601.stream swfurl=http://www.tvsector.com/wp-content/uploads/jw-player-plugin-for-wordpress/player/player.swf pageurl=http://www.futubox.com/
06:34:52 T:99766272 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
06:34:52 T:164802560 NOTICE: Creating InputStream
06:34:52 T:164802560 ERROR: rtmp server sent error
06:34:52 T:164802560 ERROR: rtmp server requested close
06:34:52 T:164802560 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmp://tv.futubox.com/live playpath=z010601.stream swfurl=http://www.tvsector.com/wp-content/uploads/jw-player-plugin-for-wordpress/player/player.swf pageurl=http://www.futubox.com/]
06:34:52 T:164802560 NOTICE: CDVDPlayer::OnExit()
06:34:52 T:164802560 NOTICE: CDVDPlayer::OnExit() deleting input stream
06:34:52 T:99766272 NOTICE: CDVDPlayer::CloseFile()
06:34:52 T:99766272 NOTICE: DVDPlayer: waiting for threads to exit
06:34:52 T:99766272 NOTICE: DVDPlayer: finished waiting
Is it possible to run this great Addon in OpenELEC?
The TV program stops ever after approximately 1 min and i dont know how to update the libRTMP.
I use OpenELEC-Fusion.x86_64-1.95.4
I installed the latest SuperTV on my Apple TV 2 and none of the channels work apart from a few. I click the channel and the play button pops up then then it just goes back to channel list. Anyone have any ideas of a fix?
(2012-05-27, 16:50)drago773 Wrote: [ -> ]I installed the latest SuperTV on my Apple TV 2 and none of the channels work apart from a few. I click the channel and the play button pops up then then it just goes back to channel list. Anyone have any ideas of a fix?
There is no fix at this time. The plugin is actually working as it should, but the sources for those links haven't been updated in ages. The creator has apparently abandoned the plugin for some reason. Sorry.
(2012-05-27, 18:29)drago773 Wrote: [ -> ] (2012-05-27, 17:23)crawl Wrote: [ -> ] (2012-05-27, 16:50)drago773 Wrote: [ -> ]I installed the latest SuperTV on my Apple TV 2 and none of the channels work apart from a few. I click the channel and the play button pops up then then it just goes back to channel list. Anyone have any ideas of a fix?
Any good alternatives?
You may have some luck in NaviX in Recently viewed under LiveTv user sections. Or SportsDevil LiveTV sections.
Using the Xeeboo skin, I don't see anything on my TV. List/Table aren't displayed properly and the following error are in the xbmc.log:
20:57:46 T:139885413644096 WARNING: Skin has invalid include: CommonVideoBackground
20:57:46 T:139885413644096 WARNING: Skin has invalid include: CommonMediaPlayingBackground
20:57:46 T:139885413644096 WARNING: Skin has invalid include: ContentPanelBackgrounds
20:57:46 T:139885413644096 WARNING: Skin has invalid include: CommonPageCount
20:57:46 T:139885413644096 WARNING: Skin has invalid include: CommonNowPlaying
20:57:46 T:139885413644096 WARNING: Skin has invalid include: BehindDialogFadeOut
20:57:46 T:139885413644096 WARNING: Skin has invalid include: ScrollOffsetLabel
20:57:46 T:139885413644096 WARNING: Skin has invalid include: WindowTitleHomeButton
20:57:46 T:139885413644096 WARNING: Skin has invalid include: Clock
20:57:46 T:139885413644096 WARNING: Skin has invalid include: CommonRootView
20:57:46 T:139885413644096 WARNING: Skin has invalid include: FullWidthList
20:57:46 T:139885413644096 WARNING: Skin has invalid include: ThumbnailView
20:57:46 T:139885413644096 WARNING: Skin has invalid include: PosterWrapView
20:57:46 T:139885413644096 WARNING: Skin has invalid include: PosterWrapView2_Fanart
20:57:46 T:139885413644096 WARNING: Skin has invalid include: MediaListView2
20:57:46 T:139885413644096 WARNING: Skin has invalid include: WideIconView
20:57:46 T:139885413644096 WARNING: Skin has invalid include: MusicVideoInfoListView
20:57:46 T:139885413644096 WARNING: Skin has invalid include: AddonInfoListView1
20:57:46 T:139885413644096 WARNING: Skin has invalid include: AddonInfoThumbView1
20:57:46 T:139885413644096 WARNING: Skin has invalid include: LiveTVView1
20:57:46 T:139885413644096 WARNING: Skin has invalid include: VisibleFadeEffect
20:57:46 T:139885413644096 WARNING: Previous line repeats 2 times.
The same here with many different skins, Why don't you adapt the addon to use standard includes?
this add on is it working ? any streams opening ? didnt Hans gave up actively looking after this a while back
