2012-09-05, 23:10
So, now that PVR has been merged with mainline XBMC, I'd like to inform you about some things:
and I probably forgot some things again that I'll add to this post later
Enjoy testing, and please report any issue you find (that hasn't been reported yet), so we can all enjoy a nice, stable, and properly working Frodo with PVR
- Pull requests will have to be sent to xbmc/xbmc now, instead of opdenkamp/xbmc. Existing pull requests will be closed and will need to be recreated
- No more issue reporting on github, but only on XBMC's trac: http://trac.xbmc.org/
- Add-ons are not included in XBMC's nightly builds, and will not be included in the official XBMC Frodo final. You will need to build them yourselves by following the instructions here: https://github.com/opdenkamp/xbmc-pvr-ad...ter/README . Or you can use an alternative source that still includes them. I will most likely provide them in my own builds, and/or make them downloadable as separate package, but that still has to be determined (still very early after the merge)
- Only the PVR add-ons that can be found on https://github.com/opdenkamp/xbmc-pvr-addons can be supported properly. If you have issues with add-ons that cannot be found there, then you should contact the add-on author, listed in the add-on information window.
- The wiki pages about PVR will be updated asap. Help is welcome to get it in shape before Frodo is final!
