Hey Guys,
I can get Windows 7 Professional 64 bit for half the cost of Home Premium.
Any reason NOT to use Professional with XBMC?
Thanks,
Owen
Hey Guys,
I've been running XBMC for nearly a year on Home Premium 64 Bit, but am considering upgrading to Windows 7 Professional 64 Bit.
Is XBMC equally compatible with Professional?
Thanks very much,
Owen
Nope.
I'm answering your 1st post, btw.
I merged your two similar threads.
Seriously?
Could you elaborate please?
(I now see the Mod merged my 2 threads which turn this simple question into a Riddle. I sent you a PM with the question in hopes of getting a clear answer. Thanks again for your help)
My apologies, your two threads are very similar, but not identical (gist of which is whether Pro will work with XBMC). I had revised my comment just prior to your reply.
You shouldn't have a problem I am using win 7 home basic with mine I chose it for the less features installed to keep the machine as light as possible
Windows 7 x64 Ultimate works fine also. If Home Basic and Ultimate work, I would wouldn't see why Professional doesn't.
7 pro 64bit here, all good.
