2012-09-07, 08:54
I'm using dual monitors with xorg.conf to configured in clone mode.
Option "DynamicTwinView" "false"
Option "TwinView" "true"
Option "TwinViewOrientation" "Clone"
However when there is a refresh rate change in XBMC (Adjust display refresh rate to match video or even manual through XBMC System settings) only primary display gets refresh rate changed to correct refresh rate, secondary display uses default refresh rate from Xorg screen mode. Is there a way around it? I'd like to clone both, resolution and refresh rate at the same time, so when there is change on one display's refresh rate xrandr should set it also for secondary monitory in clone mode.
Current log when changing refresh rate in XBMC (primary monitor changes to 60Hz, but secondary stays at 50Hz all the time)
T:3007204096 INFO: XRANDR: /usr/lib/xbmc/xbmc-xrandr --output DVI-I-1 --mode 0x1e9
[ 318.756] (II) NVIDIA(0): Setting mode "DVI-I-1: 1920x1080_59.94 @1920x1080 +0+0, HDMI-0: 1920x1080_50 @1920x1080 +0+0"
What am I missing?
Thanks for any help.
What am I missing?
