Full Version: Stuttering video
I have a vieo files that stutter while playing on xbmc. File kind of play but I only see the video progressing 1 frame in few seconds.
Here is the mediainfo and xbmc debug log, any idea what causing it.
http://pastie.org/4685287
One more example http://pastie.org/4685375
18:11:05 T:2970307392    INFO: CAESinkALSA - ALSA: pcm.c:1096:(snd_pcm_drop) PCM not set up
18:11:05 T:2970307392    INFO: Previous line repeats 1 times.
18:11:05 T:2970307392    INFO: CSoftAE::InternalOpenSink - NULL Initialized:
Go to your Audio Settings:
Disable DTS-HD
Disable True-HD
Disable LPCM
Set Speaker Number to 5.1
Enable AC3
Enable DTS
You could also have asked in the original thread, as you are running a non mainline build.
