is there a way to configure the time for the small/large skip/reverse jumps? for example, the small forward jump and backward jump are both 30 seconds, but i'd like the forward to be 30 seconds and the backward to be 8 seconds.
i can't find anywhere to set this. thoughts?
you first enable time based in settings, then you edit the values in tdata/0face008/settings.xml
okay, that almost worked. it looks like on short videos (maybe 20 minutes or less), it switches to percent seek and overrides time seek? it also screws up the seek bar.
is there any way to force it to always use time seek?
the back button goes back 7? seconds by default.
but it seems to create oddities with the seek bar (it creates a weird gap between what's being played and where the current "tick" is).
and i'd like to have the small go +/- 30 seconds instead of +/- 60 seconds, even if the back button worked properly. and the back button isn't conveniently located on my universal remote (mx-800).
so is there any way to get the time-based seek to work on short videos?
