General
Unique ID : 239386259726117307829289267620652040870 (0xB4181DD8B863E4C8A3CF85C49BB0C2A6)
Complete name : Z:\HD Content\HD Movies\Men.in.Black.3.2012.1080p.BluRay.x264.DTS-HDC\Men.in.Black.3.2012.1080p.BluRay.x264.DTS-HDC.mkv
Format : Matroska
Format version : Version 2
File size : 13.5 GiB
Duration : 1h 45mn
Overall bit rate : 18.3 Mbps
Encoded date : UTC 2012-09-06 23:37:24
Writing application : mkvmerge v5.3.0 ('I could have danced') built on Feb 9 2012 10:38:07
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 45mn
Bit rate : 16.8 Mbps
Width : 1 920 pixels
Height : 1 040 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.351
Stream size : 12.2 GiB (90%)
Writing library : x264 core 125 r2208 d9d2288
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=11 / psy=1 / psy_rd=1.10:0.05 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=240 / rc=2pass / mbtree=1 / bitrate=16800 / ratetol=1.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.20 / aq=2:1.10
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 45mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 1.12 GiB (8%)
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:06:09.578 : en:00:06:09.578
00:11:27.478 : en:00:11:27.478
00:16:58.809 : en:00:16:58.809
00:22:36.230 : en:00:22:36.230
00:31:24.633 : en:00:31:24.633
00:37:36.421 : en:00:37:36.421
00:42:43.019 : en:00:42:43.019
00:48:55.850 : en:00:48:55.850
00:53:58.235 : en:00:53:58.235
00:59:27.773 : en:00:59:27.773
01:05:52.782 : en:01:05:52.782
01:11:56.312 : en:01:11:56.312
01:19:50.619 : en:01:19:50.619
01:27:57.063 : en:01:27:57.063
01:35:30.683 : en:01:35:30.683
