2012-09-09, 23:00
I've a Mac Mini 2010 that I'm using as a media center. I've been using XBMCbuntu for a while, but thought that I would give Mountain Lion / XBMC Frodo alpha 5 a try.
I mainly use XBMC for listening to music, so I've connected a DAC (using the optical output) to achieve better sound quality. I've a lot of music with different bit resolution and sample rates. 16 bit-24 bit / 44 kHz-96 kHz. When using XBMCbuntu I could see that the DAC changed sample rate automatically depending on the sample rate of the music file. This was achieved with the help of ALSA. However when playing music in XBMC on Mac OS X, the sample rate is "locked to" whatever is set in the Audio MIDI Setup utility.
Do I need to add something in advancedsettings.xml to get automatic switching of sample-rates to work?
Another thing that I can't get to work is gapless playback. Whenever the next track starts to play, I always get a short pause. Is this also a setting?
Any suggestions on how to solve this is highly appreciated
