Full Version: Best way to organize PSX games?
Hey guys, I used to have a modded Xbox with XBMC, but it's been years since I've used it. Before I get started, I am organizing all of my romsets. While I have Good Tools for the older sets, I'm a bit clueless as to how to organize my PlayStation games.
I am converting all of them to a standard BIN/CUE format, but I was curious if I should just dump these files in a folder or create a subfolder for each game? Is there a "best practice" folder structure to follow? Dumping all of these files in a single folder seems messy since each game would have at least 2 files each, and I was wondering how it might affect games that use multiple CDs.
Any advice is welcome!
I believe the original xbox is no longer supported here.
Correct. Check out http://www.xbmc4xbox.org.uk/ for that kind of support.
@OP:
Since this applies to using it on the PC too, i thought i'd pitch in my $.02. I actually use a CD Image tool (ISO Buster) to convert the bin/cue files ti ISOs and then store them all in one folder.
