Full Version: CouchPotato only saving IMDB URL
Hi all Big Grin
I'm having issues with CouchPotato and it only saving the IMDB URL into the movie.nfo files.
At first I thought it was something to do with the option that you tick that makes it only save this URL but after checking through the GUI and making sure my configs where fine manually I figured it wasn't this.
Here is my config settings for metadata creation
[Meta]
fanartfilename = fanart.<orig_ext>
nfofilename = movie.nfo
enabled = True
posterminheight = 720
fanartminwidth = 1280
posterminwidth = 720
fanartminheight = 1280
urlonly = False
posterfilename = movie.tbn
Is there anyway other then this to force it to create more detailed METADATA files? Including the movie blurb and actors etc? Or can couchpotato only save the IMDB URL? (I figured not since of that option.
Any help is appreciated!
Cheers,
CalBoy.
