2012-09-13, 14:21
I'm currently planning a media server. I've already made the choice to go WHS 2011/FlexRaid rather than unRaid.
I have an old full tower case that will do for now to house everything. It has 6x 5.25" external bays and some internal 3.5". To allow for multiple drives I was thinking of adding in:
Silverstone CFP52B
I like the idea of the caddies in this even if you don't add in the hot swap stuff (at £5 a drive) when compared to the slightly cheaper Cooler Master offering. If I can find a cheap 5 in 3 caddy, then I may go that route. Xcase do the Norco 5 in 3 hotswap caddy (rebadged) for £60, but currently out of stock, and the pics show the older variant.
For the MB/CPU I'm currently thinking of:
Gigabyte GA-Z77X-D3H (I know it's currently slightly cheaper at dabs)
i3 3220
This combo would give me 4x SATA II and 4x SATA III on board along with 2x PCIe x8 slots to add in Supermicro AOC-SAS2LP-MV8 cards at a later date for 8x SATA III ports per card.
I'm looking at something that's possibly slightly overkill as I'm also thinking of using it for encoding when required. Also need to go IB when going the Intel route afaik to get the 2x x8 slots.
Not picked out any memory or PSU yet.
I currently have 2x Samsung F204UI and 2x Hitachi 500GB drives. I'll add a 3TB parity drive in (probably WD green)
I may well go with an SSD for the OS, though it doesn't need to boot up quickly.
I'm open to comments/suggestions
Silverstone CFP52B
i3 3220
