Full Version: Name of show is not displayed correctly
Hi
I have an annoying problem with XBMC. In my TV Show collection, my first show is always displayed with title '..'.
Also, if I go to the information of the show, he says that there is no information, but I can watch episodes perfectly.
When I remove the show uit of my library, a next show will be displayed as '..'.
Al my metadata is created by Media Center Master.
Can someone help me please?
Thanks in advance!
nvm problem solved!
(2012-09-13, 15:50)stefve Wrote: [ -> ]nvm problem solved!
The best resolutions/answers to problems/questions are the ones you discover yourself! Smile
For the benefit of any future readers of this thread who may have the same question, the ".." at the top of various lists is a link back to the parent directory (i.e., one level up). If you switch to some other view, such as thumbnails, the parent directory link will be represented by an up-arrow icon instead of "..". If you don't want the link for parent directory, you can remove it thusly:
System/Settings > Appearance > File lists > Show parent folder items (deselect it)
