Full Version: Movies and Tv Shows keyboard shortcuts
I am trying to set up a HP media center remote to work with xbmc, and installed the MCERemote add-on. I'm now trying to configure it to open up the "movies' and 'Tv Shows' menus. However I can not find a keyboard short cut to open those, any thoughts on what it might be, or how to go about creating a keyboard shortcut to? Thanks in advance.
Welcome to the XBMC forums.
See this thread, which explains how to map a key to open the "TV Shows" page: http://forum.xbmc.org/showthread.php?tid=133680
Following the links and hints there, you should be able to create a keymap for the "Movies" page as well.
Thanks so much! I knew it had to be easy.
