Full Version: Blu Ray iso loading wrong file.
Hello all. I am brand new to xbmc, and so far I am loving it.
I am having a problem with some of my Blu Ray iso files. Everything shows up correctly, but when I play the movie it plays one of the special features instead of the main movie. Is there a way to have the Blu Ray menu open instead of directly loading the movie? I would prefer this that way if I wanted to watch special features I could select them, or just pick the movie.
info:
Windows 7 pro 64
xbmc 11.0 “Eden” (windows says it's version 10.5.0.0)
Problem file: Harry Potter and the Deathly Hallows Part I.iso
Ripped with AnyDVD Image Ripper
All of my iso are in their own folders with matching names(IMDB naming convention)
Thanks in advance,
Jimi
not yet there isnt. not directly. to get menus you have to use a third party program with xbmc. i think there is supposed to be a way to pick which file to play but im not sure.
Do you know the name of the third party software?
(2012-09-14, 19:02)JimiClark Wrote: [ -> ]Is there a way to have the Blu Ray menu open instead of directly loading the movie?
Jimi
You need XBMC external player to enjoy BD menu, and these two media players are the most well known- TMT5 or PDVD12.......
You can check out this thread to setup XBMC external player- Another External Player Code, but Very Simple to Setup.....
Thanks I will check it out.
i personally prefer TMT
