2012-09-14, 20:33
I'm running OpeneELEC 1.95.7 (2.0 Beta 7) 32-bit.
HW is an ASUS 1201N ION dual core atom 330 laptop.
HDD has been removed (it crashed), and I'm running on a 8GB usb flash drive. Installed using the OpenELEC usb stick installer (created from windows).
I posted on the OpenELEC forum about but, I also tried this with the latest version of XBMCBuntu with the same results, so I fell back to using OpenELEC, where I captured the log data.
The issue is, after an undetermined/inconsistent period of time under load, the machine will freeze up. If I'm playing video, it will freeze on the current frame, and it sounds like a single audio packet will be infinitely repeating (i.e. a snip of the last sound to play from the video repeats indefinitely).
Once this happens, I can no longer ssh into the box, and any currently open ssh connections freeze and are no longer responsive. At this point, I have to physically power off the box and reboot.
I enabled debugging mode and booted the box. It appears that there is no log that I can find that persists between reboots so I opened up an SSH session and tail -f on xbmc.log until the problem occurs (sometimes 2 minutes, sometimes 45, but it seems to happen more often under load i.e. playing a video while scanning the library for changes, etc.)
Unfortunately I don't believe there is anything of use in the xbmc.log log as all of the messages are what I see scrolling during normal operation.
I was also manually querying cpu and gpu temps (cputemp and gputemp commands) and it continually overs around 62C GPU and 55C CPU, it does not increase just before crashing.
Here is a link to the xbmc.log - I was able to get this by copying the contents of the ssh putty window that was tailing the log during the crash.
http://pastebin.com/CruHaAY8
I have also tailed messages.log as well as Xorg.log; there were no errors/warnings, everything looked like standard procedure through when it crashes. I can tail those remotely and post up the log if it would help, but I'm out of ideas on where to look.
