Update Gotham Branch
- bump OpenElec revision
- Xbmc 13 Gotham (01.05.2013) commit:3f0e77e3e3
- update firmware (increase planar/float audio buffersize again, rebuild of tvservice with updated limited/full pixel encoding enums)
- fixes PGS subtitles
- remove unnecessary gl ifdef
http://forum.xbmc.org/showthread.php?tid...pid1393759
(2013-04-29, 19:00)popcornmix Wrote: [ -> ] (2013-04-28, 16:33)kire1980 Wrote: [ -> ]Again no subs on MKV and sound (AC3 5.1) on MKV is choppy... All not the case in 3.0.1. What can be wrong?
The subs one could be this:
https://github.com/xbmc/xbmc/pull/2666
Just tried rbje's last Frodo build (with the PGS fix), but unfortunately also no subs this time. Also sound had some irregularities again.
I'll post the xbmc.log and a sample file later.
Updated Frodo Branch
- new firmware and kernel (3.8.11)
http://forum.xbmc.org/showthread.php?tid...pid1350100
(2013-05-01, 22:03)kire1980 Wrote: [ -> ] (2013-04-29, 19:00)popcornmix Wrote: [ -> ] (2013-04-28, 16:33)kire1980 Wrote: [ -> ]Again no subs on MKV and sound (AC3 5.1) on MKV is choppy... All not the case in 3.0.1. What can be wrong?
Try delete guisettings. If not help only clean install.
Can anyone tell me if Frodo 12.2 changes the database version?
Thanks,
No, still 13.
Edit: Sorry, still on 12.1 - thought I was on 12.2, so not entirely sure but haven't seen anything to suggest it is likely to change.
(2013-05-02, 23:19)Bosslx Wrote: [ -> ]Can anyone tell me if Frodo 12.2 changes the database version?
Nope. All the Frodo builds and the current Gotham build are on same version.
When some wild-eyed, eight-foot-tall maniac grabs your neck, taps the back of your favorite head up against the barroom wall, and he looks you crooked in the eye and he asks you if ya paid your dues, you just stare that big sucker right back in the eye, and you remember what ol' Jack Burton always says at a time like that:
"Have ya paid your dues, Jack?" "Yessir, the check is in the mail."
CouldnĀ“t resist...
lol. That just made my night.
On Raspberry Pi with FFmpeg 1.2 (my custom builds Frodo and Gotham) some music files dont play when i try playing from hdd, pendrive, sdcard, etc.
If i use AirPlay streaming every audio files play.
With FFmpeg 0.10.6 (OpenElec 3.0.2) everything is ok. Playing fine from storage (hdd, sdcard, etc) and airplay.
Someone can confirm this??
Hello rbej,
i'm using your testbuilds since I get my rpi.
They are working great.
Currently I try to get the new abc Streaming working within the free cable plugin.
Is it possible that you can create a testbuild where ffmpeg has gnutsl or openssl Support included.
Most of the builds I saw don't use it.
Will be great because then i can test my plugin changes.
Best regards from Germany
