Full Version: OpenELEC Testbuilds for RaspberryPi
i like to continue here our OpenELEC Testbuilds thread from http://www.raspberrypi.org/phpBB3/viewto...167#p89072 for various reasons.
  • this forum is watched by many more developers, this helps to fix issues faster
  • this forum is a common place for XBMC installs, here you can get better help with your XBMC
Homepage:
http://www.openelec.tv
IRC Support Chat:
#openelec on freenode.net
Wiki:
http://wiki.openelec.tv
Official development build:
http://sources.openelec.tv/tmp/image/openelec-rpi/
Installing on RaspberryPi
http://wiki.openelec.tv/index.php?title=...spberry_Pi
Updating without loosing your settings:
http://wiki.openelec.tv/index.php?title=...g_OpenELEC
OpenELEC Development build (r11930):
http://sources.openelec.tv/tmp/image/ope...30.tar.bz2
to update a older build without reinstalling see:
After the last bigger XBMC update there was a rewrite of the XBMC code for RPi from Gimli with the goal to make the RPi port ready for merging with XBMC-master (the actual development branch for the upcoming release "Frodo"). This means there was a lot of changes, internally testing and preparing. After the XBMC Devcon one 2 weeks ago the RPi Pullrequest was merged to XBMC-master shortly after the merge of the also long waiting PVR pull request. This now means PVR and RPi support is officially part of XBMC - and PVR support is avaible for RPi too. Thats both great news - more info you can read at http://openelec.tv/news/item/250-project...nt-changes
Since then many things was fixed too:
  • XBMC with PVR support and PVR addons installed
  • Kernel linux 3.2.28 changed to the RPi foundation 3.2 kernel and updated to 3.2.28
  • some audio related issues fixed
  • fixed XVDR addon
  • fixed CEC support
  • various other improvenments, fixes and package updates
  • a nice (and fixed) Systeminfo dialog to get some informations like the serial to buy the licenses, cpu temperature, hardware revision (see screenshot)
You can install HTS TVHeadend a PVR backend via XBMC's addon system
(go to: System/Settings/Add-ons/Services/hts-tvheadend install and reboot for more informations see:
http://wiki.openelec.tv/index.php?title=...dend_addon )
It is needed to update the bootloaderfiles which you can find in the build in the folder 3rdparty/bootloader it will be done automatically if you use a build 11766 or newer. For older builds you can update locally via Windows/Linux or via ssh:
  • login via ssh to your Raspi:
    ssh [email protected]<ipaddress>
  • remount /flash r/w:
    mount -o remount,rw /flash
  • from your linux system copy the files via ssh/scp to the Raspi:
    scp 3rdparty/bootloader/* [email protected]<ipaddress>:/flash
because XBMC now supports officially RPi and PVR please use XBMC's Trac (http://trac.xbmc.org/) to report XBMC bugs and OpenELEC's github issue tracker (https://github.com/OpenELEC/OpenELEC.tv/issues) for OS related issues and feature/driver requests.
Is there any way to install this from a windows machine? I do not have access to a Linux machine with a SD slot. Is there an .img that I can use with Win32diskimager?
Cool ! Would it be a good idea to install tvh backend and two dvbs2 usb tvcards and a usb disk. To hide away and have a low power 24h dvr? How to now if this tvcards works http://sundtek.com/shop/Digital-TV-Stick...-S/S2.html
(2012-09-15, 13:10)Jönke Wrote: [ -> ]Cool ! Would it be a good idea to install tvh backend and two dvbs2 usb tvcards and a usb disk. To hide away and have a low power 24h dvr? How to now if this tvcards works http://sundtek.com/shop/Digital-TV-Stick...-S/S2.html
for the sundtek sticks we have a own addon, it will be reviewed the next days for RPi support and then released with RPi support. so i think it should be avaible within the next week
hey thanks for making this thread here!
i just wanted to mention that on the latest build 11930 i get very pixelated fanart for movies/tv. My resolution is 1080p and fanart was very crisp clean in the previous versions, but in this one I get very pixelated fanart. Im wondering if this is just an issue im experiencing, and i need to reload my DB or if its something everyone else is noticing.
Hey, I was wondering on the correct way to shut this thing down with openELEC on it?
Google told me to use either sudo shutdown -h or sudo halt but If I use either command I just get an error saying sudo not found (This is all over SSH)
Is there some other commmand I need to use? I tried poweroff and it seemed to do something similar.
(2012-09-15, 19:02)onetootreefor Wrote: [ -> ]hey thanks for making this thread here!
Thats a technical limitation we did for now on the PI. In previous version we had GPU memory issues ( running out ). So we limit the mxiumum size for images, until we have a better solution for that.
@gimli,
we had the same issue on atv2, looking at the advancedsettings you have as default, maybe you should update them, frodo has some changes related to this:
look for
<imageres>480</imageres>
<fanartres>720</fanartres>
http://forum.xbmc.org/showthread.php?tid...pid1142983
P.S. talking about the default advancedsettings
<visualizedirtyregions>off</visualizedirtyregions>
It's off by default, so no needs to set it again.
Also, keep an eye on this pull, will enable DR per default
https://github.com/xbmc/xbmc/pull/1426
I'm getting this error in some addons in latest builds
22:25:59 T:1220281440   ERROR: Leaving Python method 'XBMCAddon_xbmc_Player_play'. Exception from call to 'play' 'Incorrect type passed to "play", was expecting a "p.PlayList" but received a "p.XBMCAddon::xbmc::PlayList"' ... returning NULL
2
did the python api changed ?
Also music playback starts at 5 secs not 0, so it is off by 5 secs, only the time is wrong the playback seems to be accurate
(2012-09-15, 22:30)Jester Wrote: [ -> ]@gimli,
look for
I'm aware about the D-R PR. My job as developer to track changes in master Wink
My fault. Will fix shortly.
Can you tell me how you got the error so I can reproduce it?
xbmc-iplayer seems to suffer from the same problem...
this is code in the addon, 1chanell
    stream_url = urlresolver.HostedMediaFile(url=url).resolve()
    playlist = xbmc.PlayList(xbmc.PLAYLIST_VIDEO)
    playlist.clear()
        // some metadata code here
        playlist.add(url=stream_url, listitem=listitem)
    player = playback.Player(imdbnum=imdbnum, video_type=video_type, title=title, season=season, episode=episode, year=year)
    player.play(playlist)
    while player._playbackLock.isSet():
        xbmc.sleep(250)
22:25:59 T:1220281440   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.RuntimeError'>
                                            Error Contents: Incorrect type passed to "play", was expecting a "p.PlayList" but received a "p.XBMCAddon::xbmc::PlayList"
