Full Version: Intel NUC - Ivy Bridge (3rd Generation CPU)
There is an option "wait for network" in the settings addon.
Yeh. oE settings or settings. It's in there somewhere.
Which remote controller are you using for Nuc under Openlec ?
I'm using a Harmony 200.
@jammyb
Have you a receiver or the NUC have IR abilities ?
(2013-09-20, 08:02)jammyb Wrote: [ -> ]Try putting a delay on xbmc booting. In oE settings. Give it a 5 second delay so it can find network. Might be delaying as its still connecting.
thanks for the replay man,.. I turned off both wireless and wired networks altogether, and it still has the delay.
Exactly where can you either wait for network, or add a delay? I haven't seen that option. Sad
thanks
Legion
(2013-09-20, 14:19)Noexicaise Wrote: [ -> ]@jammyb
Only the new Haswell NUC have IR abilities.
I modded IR into my Celeron NUC. See the build thread in my sig.
(2013-09-20, 15:56)-DDD- Wrote: [ -> ]Only the new Haswell NUC have IR abilities.
Nope. Mine had full on/off capability and remote with internal IR Tongue
I would love to get my hands on one of these:
http://liliputing.com/2013/09/139-intel-...p-way.html
(2013-09-20, 18:35)jammyb Wrote: [ -> ]Nope. Mine had full on/off capability and remote with internal IR Tongue
Ok, but you have modded yours, i mean the abilities available without modding.
@jammyb: Great ! Good job ! But to complex for me...
Actually i use this one ( http://www.amazon.co.uk/Rii-2-4GHz-Wirel...ywords=Rii ) but i have a lot of issues. ( but no problem with Pivos, so,i think it's an openelec problem)
So i search for an alternative, if someone can help me...;-)
What OE Version do you use? Do you have the Problems with OE 3.0 too?
I use this one with OE 3.0, but it's a bit bigger than Rii:
http://www.amazon.co.uk/Logitech-K400-Wi...words=k400
Open elec 3.2.0 - x64
@-DDD- : And you have any issues ? Which keyboard have you choose on settings ?
PS: Sorry for english
I haven't any issues with 3.0.6, but i heard in forums that there were any with 3.1 and 3.2.
That's the reason i asked you, which version you use and if you can try the 3.0.6.
no Problem, my english is also bad Smile
3.0.6 has no deinterlacing support. So if you want to watch LiveTV, that does not look that nice.
3.2.1 will be released the next days. That one solves some nasty last minute bugs, we put in.
Btw. 3.0.6 ships with a patch that disables RC6 powersaving on Celeron Nucs, cause they just froze at that time with this feature enabled. So, you upgrade to 3.2.1, make sure RC6 is enabled again.
