(2013-10-16, 14:03)arokh Wrote: [ -> ] (2013-10-15, 00:05)voip-ninja Wrote: [ -> ]I want to see what people run into with OpenElec before I order one.
Why would you want to run OpenELEC on these? It's a great distribution for low powered devices but it's a hassle to create/install/maintain addons or do anything else than XBMC with it. I'm currently on the Ivy Bridge i5 NUC and man does Arch Linux fly on this. Using BTRFS for root allows me to easily roll back failed updates, I can use UEFI boot, I can install anything else I want including bleeding edge graphics stack software. The NUC is very powerful and deserves a real distro
I don't find it a hassle at all. If anything I found that dealing with XBMC on Windows previously was a much bigger hassle purely from an OS perspective.
You are right, an i3 or i5 NUC is a good machine for running a full desktop OS and also using a media center application package within that OS, but personally I just want a very fast and powerful appliance computer that gives great HTPC performance without all of the headaches of a "full" OS or the limitations and crappy performance of a cheap media streamer.
I have OE running on an Ivy i3 right now and it is great. It updates itself (as well as add-ons) with no input from me, and via an IR bridge it is working well with my Harmony. By comparison when I was running Windows it was a constant pain between forced updates, driver issues, etc.
The new NUC adding true 23.976 support, integrated IR, etc, at a sub $300 price point for an i3 box is a pretty good deal compared to the $500+ I spent building a custom i3 machine 18 months ago.
(2013-10-16, 21:01)Raytestrak Wrote: [ -> ] (2013-10-16, 14:23)00b5 Wrote: [ -> ]Some people want an applicance like environment. Set it up once, and forget it. NUC (espically i3/i5 ones) w/ msata can definitely DO a lot more, some people just choose to NOT have them do more.
Haswell nuc adds (hopefully) better IR support, on/off from a remote, and fixes the 24p sync issues. Thats enough to get one and JUST use OE on it for a large subset.
I have 23.976 playback on my NUC using OpenElec (Gotham does it out of the box, Frodo needed a custom xorg.conf). Or at least ... the logs say it's running at 23.976 fps.
With Ivy Bridge you will get a frame drop about every 7 minutes or so. Not noticeable to some, very noticeable to others (me).
Also, because it can't do perfect 23.976 playback there are problems with True-HD audio dropouts for example, if you are doing bit-stream and passing audio with the "sync to display" option set.
I am optimistic that OE on Haswell will not have these issues. With true 23.976 performance it shouldn't even be necessary to sync to display at all, because the clock on the NUC is going to be extremely close to that of the AVR and display.
(2013-10-16, 17:52)jayce996 Wrote: [ -> ] (2013-10-16, 14:03)arokh Wrote: [ -> ] (2013-10-15, 00:05)voip-ninja Wrote: [ -> ]I want to see what people run into with OpenElec before I order one.
what is "bleeding edge graphics stack software" ?
I don't know what he's talking about, but perhaps it's some Linux equivalent of MaDVR. I get it, some people love to tinker, they don't mind having a keyboard and mouse out when they are using the PC that's connected to their TV. Some of us just want a good playback experience and nice UI and want our stuff to work without constantly dicking with it.
I have seen people with dumbfounded looks on their faces when I pointed out that they spent 10's of hours getting things to work and employing lots of circus magic in the process when something like OE could have gotten them 90% of the way there in a matter of minutes. Some peoples time is more or less valuable than others maybe.
