Hello all!
After going through this thread, I've decided on getting the i3 NUC box but intend on streaming from my QNAP through Wifi. Has anyone had any experience on the performance of the wifi card when playing 1080p mkv files?
Varies on wifi card as you have to buy your own one!
(2013-03-28, 21:51)jammyb Wrote: [ -> ]Varies on wifi card as you have to buy your own one!
Intel Network 6235AN.HMWWB Centrino WiFi Card Advanced-N 6235 Dual Band Bluetooth Retail
Also varies on the place you live in, the type and amount of walls between the nas, router and media player location.
And whether you use your microwave or mobile phone whilst trying to stream.
What I'm getting at is. Don't use WiFi. If you can't run a length or 2 of cat5e, then Buy homeplugs!! WiFi is a nightmare for streaming 1080p!
+1 for the homeplugs suggestion. Nothing worse than a pause and wait mid film.
(2013-03-28, 23:05)jammyb Wrote: [ -> ]Also varies on the place you live in, the type and amount of walls between the nas, router and media player location.
(2013-03-28, 23:19)wgards8 Wrote: [ -> ]+1 for the homeplugs suggestion. Nothing worse than a pause and wait mid film.
I would have certainly opted for ethernet if i had the chance, however I am living in a rented place away from home and my router and NAS are situated far away at the opposite corner of the room. I have had no issues streaming all my movies on my macbook pro using wifi on XBMC, even through walls. Could it be any different on the NUC box? Thank you for your help
If it was me I wouldnt take the risk.
Try your wireless but be prepared to buy powerline
For those trying to turn the machine on via the internal USB header: that won't work either. It still doesn't get power when the machine is off. The only way to turn it on when powered down is the physical power button, or Wake-On-LAN. Also, you can set up a single timer in the BIOS.
Nice one Squigglyline! I'd seen briefly in a teardown video what could of been the power button but this has confirmed my worst fears. It'll be a solder job to get physical remote on/off power!
Can anyone contact Ben Heck and ask if he could have a go making one? :chuckle:
(2013-03-29, 00:59)Sunflux Wrote: [ -> ]For those trying to turn the machine on via the internal USB header: that won't work either. It still doesn't get power when the machine is off. The only way to turn it on when powered down is the physical power button, or Wake-On-LAN. Also, you can set up a single timer in the BIOS.
Never said about using the internal header to power it up from off. Just to fit the IR receiver internally!
But you got me thinking, is the NUC like the acer revo's in that you can set the USB ports to power up/wake from sleep? I know its not actually powered off. But at least that'll make it remotely switchable?
(2013-03-29, 08:11)jammyb Wrote: [ -> ]But you got me thinking, is the NUC like the acer revo's in that you can set the USB ports to power up/wake from sleep? I know its not actually powered off. But at least that'll make it remotely switchable?
I 'heard' that Intel doesn't allow that but I could be very wrong.
(2013-03-29, 08:11)jammyb Wrote: [ -> ] (2013-03-29, 00:59)Sunflux Wrote: [ -> ]For those trying to turn the machine on via the internal USB header: that won't work either. It still doesn't get power when the machine is off. The only way to turn it on when powered down is the physical power button, or Wake-On-LAN. Also, you can set up a single timer in the BIOS.
Well, my USB keyboard, mouse and IR receiver (only the "power" command) ARE able to wake the NUC from S3 sleep (thank goodness the IR receiver works for this!). However there's no setting - it's just a standard behavior.
I actually mentioned this earlier, because my old AOpen MiniPC that this replaces didn't supply USB power even in sleep mode, which meant the only way to turn it on each day was to hit the power button (it was too noisy to leave running in my bedroom all the time). Sleep is an okay compromise, but since the NUC boots crazy fast (about 15 seconds from cold off to Windows 7 desktop, and I don't even have all the BIOS boot speed enhancements enabled), it would be nice to be able to turn it on from a fully powered-down state. Maybe in a later model.
Yes. Or if someone invents a universal remote with WOL capabilities, we'd all be happy chappies!
So we're looking at S3 resume via USB IR then, right?
Anyone got the know-how to code this up in openELEC?
Yup, S3 resume via USB IR should work if it doesn't already work in OpenELEC.
However as a caution, I won't rule out the USB IR receiver needing to support this. I'm using the Rosewill MCE model mentioned earlier, and one of the very special things about it is that it's capable of waking a PC from S5 off state, as long as USB standby power is suppled. From what I've read, this is far from a common feature on USB IR receivers, so I'm not entirely certain if waking from sleep mode is to be expected on all such adapters, or not.
