2012-09-16, 05:01
I upgraded to 3.2.0-30. Now my box boots straight to the login screen. I can't get it to load XBMC. I tried choosing 3.2.0-24 from the boot menu but still boots to the ubuntu login screen. Anyone have some ideas on how to fix?
Log File
I don't think the log file will help. I just rebooted and there is no additional entries in it. There is a message in /var/log/boot.log that says unable to load LIRC kernel module. Could that be it?
.xsession-errors file
And from my apt log. This is when the problems started
EDIT: The problem is/was due to the xbmc nightly and not from the kernel upgrade. The nightly has since been updated and is no longer an issue. I am using the Nathan nightly in my sig. If your experiencing this issue then do an apt-get update and upgrade.
On the bright side it appears that 11.0 works fine with 3.2.0-30
Log File
Gtk-Message: Failed to load module "canberra-gtk-module"
/usr/lib/xbmc/xbmc.bin: symbol lookup error: /usr/lib/xbmc/xbmc.bin: undefined symbol: _ZTIN6TagLib8IOStreamE
Install: liblockdev1:i386 (1.0.3-1.4build2, automatic), linux-headers-3.2.0-30:i386 (3.2.0-30.48, automatic), linux-headers-3.2.0-30-generic:i386 (3.2.0-30.48, automatic), linux-image-3.2.0-30-generic:i386 (3.2.0-30.48), linux-image-3.2.0-30-generic-pae:i386 (3.2.0-30.48)
Upgrade: bind9-host:i386 (9.8.1.dfsg.P1-4ubuntu0.2, 9.8.1.dfsg.P1-4ubuntu0.3), linux-headers-generic:i386 (3.2.0.27.29, 3.2.0.30.32), dnsutils:i386 (9.8.1.dfsg.P1-4ubuntu0.2, 9.8.1.dfsg.P1-4ubuntu0.3), linux-image-generic:i386 (3.2.0.27.29, 3.2.0.30.32), libcec1:i386 (1.6.1-2, 1.8.1-1~ppa1~precise), linux-image-generic-pae:i386 (3.2.0.27.29, 3.2.0.30.32), libdns81:i386 (9.8.1.dfsg.P1-4ubuntu0.2, 9.8.1.dfsg.P1-4ubuntu0.3), libisccc80:i386 (9.8.1.dfsg.P1-4ubuntu0.2, 9.8.1.dfsg.P1-4ubuntu0.3), linux-image:i386 (3.2.0.27.29, 3.2.0.30.32), liblwres80:i386 (9.8.1.dfsg.P1-4ubuntu0.2, 9.8.1.dfsg.P1-4ubuntu0.3), xbmc-bin:i386 (11.9.6~git201209091918~34cfe65-1~ppa1~precise, 11.9.6~git201209151727~1e7f8e7-1~ppa1~precise), libbind9-80:i386 (9.8.1.dfsg.P1-4ubuntu0.2, 9.8.1.dfsg.P1-4ubuntu0.3), xbmc:i386 (11.9.6~git201209091918~34cfe65-1~ppa1~precise, 11.9.6~git201209151727~1e7f8e7-1~ppa1~precise), libcec:i386 (1.6.2-1~ppa1~precise, 1.8.1-1~ppa1~precise), libcec-dev:i386 (1.6.2-1~ppa1~precise, 1.8.1-1~ppa1~precise), libisccfg82:i386 (9.8.1.dfsg.P1-4ubuntu0.2, 9.8.1.dfsg.P1-4ubuntu0.3), libisc83:i386 (9.8.1.dfsg.P1-4ubuntu0.2, 9.8.1.dfsg.P1-4ubuntu0.3), linux-generic:i386 (3.2.0.27.29, 3.2.0.30.32)
Error: Sub-process /usr/bin/dpkg returned an error code (1)
End-Date: 2012-09-15 14:53:19
