same here with channels, 1st start works ok, some switching also ok (still very slow here), after that same issue as described above ...
some log here
07:28:53 T:8916 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
07:28:53 T:1920 NOTICE: Thread CDVDPlayer start, auto delete: false
07:28:53 T:1920 NOTICE: Creating InputStream
07:28:54 T:7444 NOTICE: Thread CFileCache start, auto delete: false
07:28:56 T:1920 NOTICE: Previous line repeats 1 times.
07:28:56 T:1920 NOTICE: Creating Demuxer
07:28:56 T:2372 NOTICE: Thread CFileCache start, auto delete: false
07:29:21 T:8332 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
07:29:21 T:8332 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
07:29:21 T:8332 ERROR: XFILE::CFileCache::Open - failed to open source <http://alturismo:
[email protected]:8089/status.html?aktion=status>
07:29:21 T:8332 ERROR: PVR - exception 'invalid string position' caught while trying to call 'PVR::CPVRClient::SignalQuality' on add-on 'DVBViewer:127.0.0.1'. Please contact the developer of this add-on: jdembski, A600
07:29:27 T:8336 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
07:29:27 T:8336 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
07:29:27 T:8336 ERROR: XFILE::CFileCache::Open - failed to open source <http://alturismo:
07:29:27 T:8336 ERROR: PVR - exception 'invalid string position' caught while trying to call 'PVR::CPVRClient::SignalQuality' on add-on 'DVBViewer:127.0.0.1'. Please contact the developer of this add-on: jdembski, A600
07:29:27 T:1920 WARNING: could not find codec parameters for pvr://channels/tv/Alle TV-Kanäle/310.pvr
07:29:28 T:4760 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
07:29:28 T:4760 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
07:29:28 T:4760 ERROR: XFILE::CFileCache::Open - failed to open source <http://alturismo:
[email protected]:8089/api/epg.html?lvl=2&channel=563521184923762&start=41229.228495&end=41232.270162>
07:29:28 T:4760 ERROR: AddOnLog: DVBViewer Client: Dvb::GetEPGForChannel Unable to parse XML. Error: 'Warning: No XML tag found'
07:29:28 T:4760 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'DVBViewer:127.0.0.1' returned an error: server error
07:29:28 T:4760 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Sport HD 2 (deu)' from client '1': server error
07:29:28 T:4760 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Sport HD 2 (deu)'
07:29:41 T:7544 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
07:29:41 T:7544 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
07:29:41 T:7544 ERROR: XFILE::CFileCache::Open - failed to open source <http://alturismo:
[email protected]:8089/api/timerlist.html>
07:29:48 T:8332 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
07:29:48 T:8332 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
07:29:48 T:8332 ERROR: XFILE::CFileCache::Open - failed to open source <http://alturismo:
07:29:48 T:8332 ERROR: PVR - exception 'invalid string position' caught while trying to call 'PVR::CPVRClient::SignalQuality' on add-on 'DVBViewer:127.0.0.1'. Please contact the developer of this add-on: jdembski, A600
07:29:52 T:8336 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
07:29:52 T:8336 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
07:29:52 T:8336 ERROR: XFILE::CFileCache::Open - failed to open source <http://alturismo:
07:29:52 T:8336 ERROR: PVR - exception 'invalid string position' caught while trying to call 'PVR::CPVRClient::SignalQuality' on add-on 'DVBViewer:127.0.0.1'. Please contact the developer of this add-on: jdembski, A600
07:29:58 T:1920 WARNING: could not find codec parameters for pvr://channels/tv/Alle TV-Kanäle/310.pvr
07:30:03 T:8336 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 7
07:30:03 T:8336 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
07:30:03 T:8336 ERROR: XFILE::CFileCache::Open - failed to open source <http://alturismo:
07:30:03 T:8336 ERROR: PVR - exception 'invalid string position' caught while trying to call 'PVR::CPVRClient::SignalQuality' on add-on 'DVBViewer:127.0.0.1'. Please contact the developer of this add-on: jdembski, A600
07:30:03 T:8916 NOTICE: CDVDPlayer::CloseFile()
07:30:03 T:8916 NOTICE: DVDPlayer: waiting for threads to exit
