(2012-09-29, 17:55)A600 Wrote: [ -> ]Could you upload the full debug log?
just try it again, i fogett to delte all - lcurl. and error-message was the same
okay no success here is the log
xbmc.log
befor compiling i delete all "-lcurl" i found in:
addons/MAKEFILE &
addons/pvr.dvbviewer/MAKEFILE
(2012-09-29, 18:30)tvfreak Wrote: [ -> ]xbmc.log
18:34:55 T:1213592672 ERROR: Unable to load /storage/.xbmc/addons/pvr.dvbviewer/XBMC_dvbviewer.pvr, reason: libcurl-gnutls.so.4: cannot open shared object file: No such file or directory
Are you using the PVR I uploaded? because the one from your log needs curl.
Try to completely uninstall the addon and install the one I uploaded.
(2012-09-29, 18:50)A600 Wrote: [ -> ]Are you using the PVR I uploaded? because the one from your log needs curl.
no i'm yousing pvr2.zip
and every try i delete the old addon, but nobody is perfekt, so i try it again!
sorra for question, your pvr2 is correct without curl?
(2012-09-29, 18:55)tvfreak Wrote: [ -> ]sorra for question, your pvr2 is correct without curl?
Yes.
I know what the problem is: your Openelec version is too old:
Quote:01:00:19 T:1076068880 NOTICE: Starting XBMC (12.0-ALPHA6 Git:f196cd1), Platform: Linux (OpenELEC - Version: devel-20120917034656-r11937, 3.2.28 armv6l). Built on Sep 17 2012
You need a newer build (at least from Sep 20) with this
change Git:dd8736a
Wow, I just came here to say that this is by far the most stable PVR integration I've tried.
Much more stable than the TVHeadend integration and even now faster and more stable channel switching than Mediaportals DVB Server.
The only thing which could be better would be channel switching times imo.
Thanks for all the awesome work.
OK, good news finally, the plugin now works in XBMC on rhe RPi.
I've got some other issues now though, not sure where they come from, will have to investigate. Right now everything is extremely slow on my Pi, even SDTV doesn't work properly anymore, with LiveTV or without...oh bother.
CommanderROR
can you tell me witch xbmc version an witch pvr.version can#t get it work
I'm using the latest openelec, 2016 I think. The pvr version is the last one A600 posted on this thread.
(2012-09-29, 21:30)CommanderROR Wrote: [ -> ]I'm using the latest openelec, 2016 I think. The pvr version is the last one A600 posted on this thread.
can you send me a link where you download your openelec?
Sure, but stay away from the 2016 build, it caused a lot of problems for me. 2006 is mostly OK, I'll try 2014 now.
http://openelec.thestateofme.com/
Hmm...2014 also did not work for me, some problems with sound and generally bad performance...funny..back to 2006 then. I hope that works...but my old raspbmc image works fine, so not a general problem...hmmm...
(2012-09-29, 21:47)CommanderROR Wrote: [ -> ]Hmm...2014 also did not work for me, some problems with sound and generally bad performance...funny..back to 2006 then. I hope that works...but my old raspbmc image works fine, so not a general problem...hmmm...
thanks, i tested 12006 and 12016 both had problems with sound (audiodelay h264) but pvr.addon works fine.
(2012-09-29, 21:07)CommanderROR Wrote: [ -> ]OK, good news finally, the plugin now works in XBMC on rhe RPi.
I'm glad to hear that
How is the EPG loading speed?
Epg was slow...but bearable.
tvfreak interesting about the audio delay. It's actually not that bad in 2006, I wonder that there is no talk about the Sound issues on the OE forums... Ok, enough off topic.
(2012-09-30, 00:32)CommanderROR Wrote: [ -> ]Epg was slow...but bearable.
@tvfreak interesting about the audio delay. It's actually not that bad in 2006, I wonder that there is no talk about the Sound issues on the OE forums... Ok, enough off topic.
there is a new version 2017, audiodelay is not on every channel. "das erste" is okay "zdf info" it's 1second.
what is the difference between the nightlies from today vs. yesterday? The add on wont start with Windows XBMCSetup-20121001-79e7c0c-master.exe from today.
