2012-09-19, 05:52
I have XBMCbuntu installed on a Zotac ND01
Everything working fine, except for 1 little annoyance.
I had a TV show listed from my server, but it was adding it to the library under the wrong title due to naming.
I have renamed the folder and files in order for it to be added properly to the library. The problem, is that it is still adding the wrong show.
Example.
I had "myshow" in folder, and xbmc was adding it in library as is. But the show was really "myshoworiginal"
So i renamed the folder "myshoworiginal" and now xbmc adds it as that, BUT it is still adding "myshow" in the library as well.
When I highlight and select TV Show information and look at path, it is pointing to the old folder "myshow" which is not even in my server anymore?!?
I can delete it from library, but when I reboot or update library, it shows up again.
Bit of a noob question I guess, but I just can't find info on this.
Example.
