2012-09-20, 09:33
Hi guys,
I haven't been able to find anyone with a similar problem to this. I have my Aeon set to use the Landscape view for my TV shows and seasons. It was working fine for a long time, but via one of the XBMC updates a few months ago, my seasons started becoming duplicted. I'll try and explain as best I can...
My top level TV Show menu is fine. I have all my shows in Landscape view: no problem. The issue occurs when I go to a show that has multiple seasons. Let's use 'The Walking Dead' as an example. I go into the show itself and I am now getting 6 selections rather than 3. I see 'All Season', 'Season 1' and 'Season 2'. These three have the correct artwork as expected. However, I also have duplicates of these 3 but with no artwork, just the standard default icon. I am able to select them - and they function as normal - but obviously I dont want the extra set of selections and have no idea why they started to appear. The problem doesn't seem to occur in other views. Just Landscape.
As for a solution: I've tried removing the userdata folder and rescraping the shows. Doesn't seem to work. I've also taken a look at my folder structure which seems correct...
TV Shows/The Walking Dead/Season 01/The Walking Dead S01E01.mkv etc.
The same issue also occurs in Aeon MQ3 (I'm using Aeon MQ4 BTW). I assume the problem is linked to XBMC itself, but seeing as it's something that's specific to this layout/skin, I wanted to post it here.
Not sure if anyone's experienced this or has any tips for how to solve it. Thanks in advance.
