2012-09-22, 16:48
2012-09-22, 18:35
It's an option in the advancedsettings.xml, particular to the <musiclibrary>, and <videolibrary> sections, called <itemseparator>.
EDIT - I think this may not be what you had in mind though... I'm not sure if your request is specific to the scrapers, or is an xbmc thing.
2012-09-23, 19:02
Thanks for the answer Thrack76,
I tried with no success.
I want xbmc in the movie list ignore what is before the apostrophe char.
For example, a movie with the name "L'impossibile" has to be sorted as "impossibile"
I just added the sort token "L" in languageinfo.xml, but now I've to tell xbmc to view the apostrophe char as a space (separator)..
2012-09-29, 22:06
up
2012-09-30, 01:35
Would it not be:
Or is that for something different?
<sorttokens>
<token separators="'">L</token>
</sorttokens>
2012-09-30, 10:54
I don't know, I'm asking for this.
But I never saw that type of sorttoken
Now I have:
In the file langinfo.xml (usr/share/xbmc/language/Italian):
<sorttokens>
<token>L</token>
</sorttokens>
In the file advancedsettings.xml (home/xbmc/.xbmc/userdata/advancedsettings.xml):
<sorttokens>
<token>'</token>
</sorttokens>
but it doesn't work
Now I have:
<sorttokens>
<token>L</token>
</sorttokens>
<sorttokens>
<token>'</token>
</sorttokens>
but it doesn't work
2012-10-06, 14:26
Up, please
2014-04-04, 13:51
After 2 and half year, I'm alwaus stucked with the same problem.
In the meantime someone solved it?
In italian L' is equivalent to "lo, la, le" (the in english)
As Un' is equivalent to "una" (a in english)
Now I've:
- Barbie
- Un bel giorno
- Il buono
- Incognito
- Jane
- L'altro
- L'intruso
- La bella vita
- Osteria
- Un'ora
An example of how it should be:
- L'altro
- Barbie
- Un bel giorno
- Il buono
- Incognito
- L'intruso
- Jane
- La bella vita
- Un'ora
- Osteria
Now I've:
- Barbie
- Un bel giorno
- Il buono
- Incognito
- Jane
- L'altro
- L'intruso
- La bella vita
- Osteria
- Un'ora
- L'altro
- Barbie
- Un bel giorno
- Il buono
- Incognito
- L'intruso
- Jane
- La bella vita
- Un'ora
- Osteria
2014-09-17, 12:05
(2014-04-04, 13:51)poisons Wrote: [ -> ]After 2 and half year, I'm alwaus stucked with the same problem.
Now I've:
- Barbie
- Un bel giorno
- Il buono
- Incognito
- Jane
- L'altro
- L'intruso
- La bella vita
- Osteria
- Un'ora
- L'altro
- Barbie
- Un bel giorno
- Il buono
- Incognito
- L'intruso
- Jane
- La bella vita
- Un'ora
- Osteria
To solve the problem add these lines in advancedsettings.xml file
<sorttokens>
<token separators="'">Un</token>
</sorttokens>
2015-01-12, 14:10
Just to say it Works!!
Thanks a lot Calosgheros
