Full Version: Mountain Lion won't autostart nfsd service?
Hello everyone, quick question
My NFS sharing from my Macbook Pro with Mountain Lion to my ATV2 is working perfect, except for the fact that everytime i restart my Mac, I have to manually "sudo nfsd start", if not it does not start.
Is there any way I can set it up to autostart? I googled it and did not find any relevant info.
sudo nfsd enable
Does not work unfortunately. Even though enabled it does not auto start Sad
(2012-09-24, 23:07)ipnd Wrote: [ -> ]Does not work unfortunately. Even though enabled it does not auto start Sad
A couple of things to try. First, try repairing permissions. If that does not work I would suggest using a program like DiskWarrior. I am also running NFS server on one of my Macs and have not seen the issue that you are having. I am running 10.8.2 and I just rebooted my Mac-Mini and the NFS started up automatically.
Thanks for the suggestion winestock! Even though this post is a few years old, I was having the same problem in Mavericks and I had set up NFS for my Apple TV XBMC. I finally got NFS set up correctly, but found I had to manually start it in Terminal after every reboot. I tried repairing permissions as you suggested and it worked! Thanks so much for your help!
