2012-09-24, 01:46
I installed the PlexBMC addin using the most recent versions of software available. When I goto start PleXBMC, i get an error message stating Unable to Connect timed out. From the same machine where XBMC is installed, I can load the Plex client and it works. Here is a sniplet from the log file.
17:06:46 T:5420 NOTICE: ===== PLEXBMC START =====
17:06:46 T:5420 NOTICE: PleXBMC -> running on (2, 6, 6, 'final', 0)
17:06:46 T:5420 NOTICE: PleXBMC -> Running with cElementTree on Python 2.5+
17:06:46 T:5420 NOTICE: PleXBMC -> Settings hostname and port: 192.168.0.5:32400
17:06:46 T:5420 NOTICE: PleXBMC -> Flatten is: 0
17:06:46 T:5420 NOTICE: PleXBMC -> Settings streaming: 1
17:06:46 T:5420 NOTICE: PleXBMC -> Setting secondary: false
17:06:46 T:5420 NOTICE: PleXBMC -> Setting debug to true
17:06:46 T:5420 NOTICE: PleXBMC -> Setting stream Control to : 1
17:06:46 T:5420 NOTICE: PleXBMC -> Running skin: skin.confluence
17:06:46 T:5420 NOTICE: PleXBMC -> Running watch view skin: xbmc
17:06:46 T:5420 NOTICE: PleXBMC -> serverList is 'Primary', '192.168.0.5:32400', False (wiki)
17:06:46 T:5420 NOTICE: PleXBMC -> Script argument is 0
17:06:46 T:5420 NOTICE: == ENTER: get_params ==
17:06:46 T:5420 NOTICE: PleXBMC -> get_params: Parameter string:
17:06:46 T:5420 NOTICE: PleXBMC -> get_params: Returning: []
17:06:46 T:5420 NOTICE: PleXBMC -> []
17:06:46 T:5420 NOTICE: PleXBMC -> Mode: None
17:06:46 T:5420 NOTICE: PleXBMC -> URL: None
17:06:46 T:5420 NOTICE: PleXBMC -> Name: None
17:06:46 T:5420 NOTICE: PleXBMC -> ID: None
17:06:46 T:5420 NOTICE: == ENTER: ROOT() ==
17:06:46 T:5420 NOTICE: PleXBMC -> ROOT: Using list of 1 servers: 'Primary', '192.168.0.5:32400', False (wiki)
17:06:46 T:5420 NOTICE: == ENTER: getURL ==
17:06:46 T:5420 NOTICE: PleXBMC -> getURL: url = http://192.168.0.5:32400/system/library/sections
17:20:16 T:5420 NOTICE: Unable to connect to 192.168.0.5:32400
Reason: timed out
17:20:16 T:5420 NOTICE: ===== PLEXBMC STOP =====
17:20:20 T:4688 NOTICE: -->Python Interpreter Initialized<--
17:20:20 T:4688 ERROR: C:\Documents and Settings\ccc1997\Application Data\XBMC\addons\plugin.video.plexbmc\default.py:2: DeprecationWarning: the sha module is deprecated; use the hashlib module instead
import sys,os,datetime, time, sha, inspect, base64
17:20:20 T:4688 NOTICE: ===== PLEXBMC START =====
17:20:20 T:4688 NOTICE: PleXBMC -> running on (2, 6, 6, 'final', 0)
17:20:20 T:4688 NOTICE: PleXBMC -> Running with cElementTree on Python 2.5+
17:20:20 T:4688 NOTICE: PleXBMC -> Settings hostname and port: 192.168.0.5:32400
17:20:20 T:4688 NOTICE: PleXBMC -> Flatten is: 0
17:20:20 T:4688 NOTICE: PleXBMC -> Settings streaming: 1
17:20:20 T:4688 NOTICE: PleXBMC -> Setting secondary: false
17:20:20 T:4688 NOTICE: PleXBMC -> Setting debug to true
17:20:20 T:4688 NOTICE: PleXBMC -> Setting stream Control to : 1
17:20:20 T:4688 NOTICE: PleXBMC -> Running skin: skin.confluence
17:20:20 T:4688 NOTICE: PleXBMC -> Running watch view skin: xbmc
17:20:20 T:4688 NOTICE: PleXBMC -> serverList is 'Primary', '192.168.0.5:32400', False (wiki)
17:20:20 T:4688 NOTICE: PleXBMC -> Script argument is 0
17:20:20 T:4688 NOTICE: == ENTER: get_params ==
17:20:20 T:4688 NOTICE: PleXBMC -> get_params: Parameter string:
17:20:20 T:4688 NOTICE: PleXBMC -> get_params: Returning: []
17:20:20 T:4688 NOTICE: PleXBMC -> []
17:20:20 T:4688 NOTICE: PleXBMC -> Mode: None
17:20:20 T:4688 NOTICE: PleXBMC -> URL: None
17:20:20 T:4688 NOTICE: PleXBMC -> Name: None
17:20:20 T:4688 NOTICE: PleXBMC -> ID: None
17:20:20 T:4688 NOTICE: == ENTER: ROOT() ==
17:20:20 T:4688 NOTICE: PleXBMC -> ROOT: Using list of 1 servers: 'Primary', '192.168.0.5:32400', False (wiki)
17:20:20 T:4688 NOTICE: == ENTER: getURL ==
17:20:20 T:4688 NOTICE: PleXBMC -> getURL: url = http://192.168.0.5:32400/system/library/sections
18:13:53 T:4688 NOTICE: Unable to connect to 192.168.0.5:32400
Reason: timed out
18:13:53 T:4688 NOTICE: ===== PLEXBMC STOP =====
I can load the url from the logfile (http://192.168.0.5:32400/system/library/sections), but the only thing that is contained in that page is:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<MediaContainer noHistory="0" replaceParent="0" size="0" identifier="com.plexapp.system"/>
Is it that the addin is too old and no longer supported?
Reason: timed out
Reason: timed out
