Full Version: Videos skipping directly to files section.
Is it possible to change this so that it doesn't skip right to the files. I like using the recently added and everytime I open "Videos" from the main screen it jumps me right into the files section and also half way down the list so I have to scroll up then hit to go back Which is really annoying.
I have looked in the settings but can't find a way to fix this. I know it is this skin since the default doesn't do it.
apart from modding the skin, there's no way to change it.
you could of course use the 'movies > recently added' submenu button instead.
