Is there an addon that can dl all subs to all my shows at once? And i would prefere if you can set prefered lang so it takes swedish subs first and if that does not exist take english subs.
Is´nt there anything like this out there?
I think the issue would be with syncing. Downloading subs requires not only the correct name, but also for the subs to be synced to the audio correctly. Considering that different rips may be different lengths, or directors cuts may have different scenes or whatever.
I guess that a bulk sub scraper would be possible, but would throw up an awful lot of false positives and would probably not be worth it as you'd probably have to re-download a lot of them anyway.
That is true my friend thank you for clearing it up för me
There is no addon but there is a python module you can do it that. Search subliminal on web.
Guess that require me to do an addon or py script to make it work?
Anyone intrested in making this to an addon for xbmc? Since it uses hash it would get the right one every time?
