Yes, Hi
I have the doctor who specials on my pc but for some reason they dnt show in xmbc, ive looked at the wiki and tried what it suggested but it didn't work please help
als if it help my files are named like this "Doctor Who (2005) - 0xSpecial 9 - The Next Doctor.avi" as they are named using "filebot" which connects to "thetvdb.com" and names them propperly, now ive triead naming the specials folder "Season 0" but they still dont show, how do i fix this?
Doctor Who (2005) - 0x09
Doctor Who (2005) - 0x9
(2012-09-24, 19:23)Martijn Wrote: [ -> ]Doctor Who (2005) - 0x09
Man that's terrible, thetvdb should fix that, oh well, this worked, thanks
(2012-09-24, 19:24)rjack12 Wrote: [ -> ] (2012-09-24, 19:23)Martijn Wrote: [ -> ]Doctor Who (2005) - 0x09
No you should fix that.
it's called reg-ex and the way you had it isn't recognised by the standard XBMC layout for filenaming
http://wiki.xbmc.org/index.php?title=Add...s/TV_shows
(2012-09-24, 19:29)Martijn Wrote: [ -> ] (2012-09-24, 19:24)rjack12 Wrote: [ -> ] (2012-09-24, 19:23)Martijn Wrote: [ -> ]Doctor Who (2005) - 0x09
The thing is though, every other episode (non special) i renamed through "filebot" worked correctly in xbmc, its only the speicals it has porblems with, using "filebot" for normal tv show eps just comes out like this "Doctor Who (2005) - 1x01 - Rose" and works perfectly in xbmc
eh works for every other tv show, thanks for the help, its very much appreciated
is there a way to save settings so if i re installed windows i wouldn't have to re download all the skins, artwork and plugins? like a back up of your personal settings in xbmc?
