Full Version: [SOLVED] HDMI video problem - no signal after 10min?
Hi
I'm experiencing some problems with my HTPC.
As it seems now it stops sending signal over HDMI after 10 minutes of inactivity.
In this case inactivity means playing a movie of tv show and not pressing any keys.
When this problem occurs I press a button on my remote and it will send signal again.
I doubt this is a XBMC problem but I guess here are a lot of people who are able to help me with this problem.
Anyone any suggestions?
you could try this setting the the xorg.conf
Regards alfton
Section "ServerFlags"
Option "BlankTime" "0"
Option "StandbyTime" "0"
Option "SuspendTime" "0"
Option "OffTime" "0"
EndSection
Thanks a lot. This did the trick for me!
