2012-09-26, 04:30
Synology NAS changed its ip on reboot and now Nothing is working on xbmc, but when i scroll to sources it takes ages and then freezes?
any ideas
any ideas
(2012-09-26, 07:37)Koying Wrote: [ -> ]In the future, avoid using the ip address when defining your sources.
Use a fqdn or a share name, depending on the protocol used.
(2012-09-26, 08:27)Cranial Wrote: [ -> ](2012-09-26, 07:37)Koying Wrote: [ -> ]In the future, avoid using the ip address when defining your sources.
If the Synology is anything like the QNAP, this may not be too successful. I'd stick with IP and just make the NAS static on your network. You can do this via the router or on the NAS.
(2012-09-26, 19:46)ChipsAhoy Wrote: [ -> ](2012-09-26, 07:37)Koying Wrote: [ -> ]In the future, avoid using the ip address when defining your sources.
Name resolving for every entry really slowed down the Library display. It didn't impact playback, but the Library browsing needs every advantage it can get, in my experience.
(2012-09-26, 20:03)Koying Wrote: [ -> ](2012-09-26, 19:46)ChipsAhoy Wrote: [ -> ](2012-09-26, 07:37)Koying Wrote: [ -> ]In the future, avoid using the ip address when defining your sources.
I don't know your setup, but there is normally no access to the files while browsing the library, besides maybe thumbs generation the first time if they do not exist.
