12:16:39 T:150474752 NOTICE: -----------------------------------------------------------------------
12:16:39 T:150474752 NOTICE: Starting XBMC (12.0-ALPHA5 Git:20120831-12840c2), Platform: Darwin iOS (11.0.0 iPad3,1, Version 5.1.1 (Build 9B206)). Built on Sep 4 2012
12:16:39 T:150474752 NOTICE: special://xbmc/ is mapped to: /private/var/stash/Applications.Nghs1y/XBMC.app/XBMCData/XBMCHome
12:16:39 T:150474752 NOTICE: special://xbmcbin/ is mapped to: /private/var/stash/Applications.Nghs1y/XBMC.app/XBMCData/XBMCHome
12:16:39 T:150474752 NOTICE: special://masterprofile/ is mapped to: /var/mobile/Library/Preferences/XBMC/userdata
12:16:39 T:150474752 NOTICE: special://home/ is mapped to: /var/mobile/Library/Preferences/XBMC
12:16:39 T:150474752 NOTICE: special://temp/ is mapped to: /var/mobile/Library/Preferences/XBMC/temp
12:16:39 T:150474752 NOTICE: special://frameworks/ is mapped to: /Applications/XBMC.app/Frameworks
12:16:39 T:150474752 NOTICE: The executable running is: /Applications/XBMC.app/XBMC
12:16:39 T:150474752 NOTICE: Local hostname: iPad
12:16:39 T:150474752 NOTICE: Log File is located: /var/mobile/Library/Preferences/xbmc.log
12:16:39 T:150474752 NOTICE: load settings...
12:16:39 T:150474752 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:16:39 T:150474752 NOTICE: loading special://masterprofile/guisettings.xml
12:16:39 T:150474752 NOTICE: Getting hardware information now...
12:16:39 T:150474752 INFO: Using analog output
12:16:39 T:150474752 INFO: AC3 pass through is enabled
12:16:39 T:150474752 INFO: DTS pass through is enabled
12:16:39 T:150474752 DEBUG: Error: Requested setting (audiooutput.passthroughaac) was not found. It must be case-sensitive
12:16:39 T:150474752 INFO: AAC pass through is disabled
12:16:39 T:150474752 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:16:39 T:150474752 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
12:16:39 T:150474752 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
12:16:39 T:150474752 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/rtmp/mms/udp
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: flv/aacp/sdp
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdfile
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
12:16:39 T:150474752 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
12:16:39 T:150474752 NOTICE: Loaded playercorefactory configuration
12:16:39 T:150474752 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:16:39 T:150474752 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
12:16:39 T:150474752 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
12:16:39 T:150474752 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
12:16:39 T:150474752 NOTICE: Default DVD Player: dvdplayer
12:16:39 T:150474752 NOTICE: Default Video Player: dvdplayer
12:16:39 T:150474752 NOTICE: Default Audio Player: paplayer
12:16:39 T:150474752 NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:16:39 T:150474752 NOTICE: Log level changed to 0
12:16:39 T:150474752 NOTICE: Loading media sources from special://masterprofile/sources.xml
12:16:39 T:150474752 NOTICE: Found possible resolution for display 0 with 1024 x 768
12:16:39 T:150474752 NOTICE: Checking resolution 12
12:16:39 T:150474752 ERROR: No matching mode found!
12:16:39 T:150474752 NOTICE: GL_VENDOR = Imagination Technologies
12:16:39 T:150474752 NOTICE: GL_RENDERER = PowerVR SGX 543
12:16:39 T:150474752 NOTICE: GL_VERSION = OpenGL ES 2.0 IMGSGX543-63.24
12:16:39 T:150474752 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.0
12:16:39 T:150474752 NOTICE: GL_EXTENSIONS = GL_OES_depth_texture GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_vertex_array_object GL_EXT_blend_minmax GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_discard_framebuffer GL_EXT_occlusion_query_boolean GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_texture_filter_anisotropic GL_EXT_texture_rg GL_APPLE_framebuffer_multisample GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_APPLE_texture_max_level GL_IMG_read_format GL_IMG_texture_compression_pvrtc
12:16:40 T:150474752 NOTICE: initializing playlistplayer
12:16:40 T:150474752 NOTICE: DONE initializing playlistplayer
12:16:41 T:150474752 NOTICE: /var/mobile/Library/Preferences/XBMC/addons/skin.re-touched/sounds/sounds.xml, Line 0
Failed to open file
12:16:41 T:150474752 NOTICE: initialize done
12:16:41 T:150474752 NOTICE: Running the application...
12:16:41 T:150474752 ERROR: Texture manager unable to load file: special://skin/backgrounds/SKINDEFAULT.jpg
12:16:41 T:150474752 NOTICE: Webserver: Starting...
12:16:41 T:150474752 NOTICE: WebServer: Started the webserver
12:16:41 T:150474752 NOTICE: ES: Starting event server
12:16:41 T:150474752 NOTICE: starting zeroconf publishing
12:16:41 T:232886272 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
12:16:41 T:232886272 NOTICE: UDP: Listening on port 9777
12:16:41 T:230174720 NOTICE: -->Python Interpreter Initialized<--
12:16:41 T:229642240 ERROR: GetDirectory - Error getting /var/mnt/mount1/DCIM/
12:16:51 T:186126336 ERROR: Previous line repeats 4 times.
12:16:51 T:186126336 NOTICE: -->Python Interpreter Initialized<--
12:16:51 T:150474752 ERROR: Texture manager unable to load file: special://skin/backgrounds/SKINDEFAULT.jpg
12:17:00 T:240074752 NOTICE: -->Python Interpreter Initialized<--
12:17:01 T:240074752 NOTICE: Calling API:
http://www.dr.dk/NU/api/programseries
12:17:02 T:250843136 NOTICE: -->Python Interpreter Initialized<--
12:17:47 T:239190016 ERROR: XBPyThread:
top - script didn't stop in 5 seconds - let's kill it
12:17:49 T:150474752 ERROR: GetDirectory - Error getting plugin://plugin.video.drnu/?show=azProgramSeries
12:17:49 T:150474752 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.drnu/?show=azProgramSeries) failed
12:17:49 T:240074752 NOTICE: -->Python Interpreter Initialized<--
